Reply 60 of 100, by overload86
HandOfFate wrote on 2020-10-12, 17:26:
I made a Python script to populate the Launchbox.txt file. I can polish it a bit and share it.
I would appreciate that very much. In my instance I would want the program to go through a single folder, make an entry for every BAT file it finds in there and ask for a title on games it cannot find in the xml. Possibly appending "SETUP" to every bat file as the "configuration entry", since all my .bat files are set up with a small utility I wrote a few years ago.
I basically went into every game folder and configured the game, looked at the executables (I use a 4dos alias named "dire" for dir "executables" that is just "dir /p *.exe *.com *.bat >&>nul")
and call "mkbat <BATCH NAME> <RUN_FILE> [optional: <SETUP_FILE>"
and my tool places the batch file in the right place.
That is exactly why I would love to not do everything manually again. But the menu system would be so much easier for my 60 year old mother to navigate than having a list of 8-char file names that she has to input in a cmd prompt xD
Haven't even thought about your approach of writing my own program to look at the stuff and parsing the xml file... But I also would have no idea how to parse a file and would have to learn that, the last time I had to do it the programming language thankfully had a method that handled the parsing and even that took me 4 nights xD
My tools I actually wrote in Quick Basic directly in dosbox haha.
Reply 62 of 100, by leileilol
overload86 wrote on 2020-10-13, 05:02:
Same, but would prefer a DBGL import
long live PCem
Reply 63 of 100, by HandOfFate
It seems DBGL uses a '100% Java' database engine called hsqldb. Making an external conversion tool for it shouldn't be difficult, but integrating it into a Visual Basic for DOS program would be... challenging.
I'll try to wrap up the tool I made somewhere this week, so you can use it or use it as a basis for your own wishes 😀
Am486 DX4 120MHz, no L2, 16MB, Tseng ET4000/W32 1MB VLB, ESS ES1869 /// 5x86 133MHz, 256kb L2, 64MB, S3 Virge/DX 4MB PCI, SB16 + Yucatan FX, PicoGUS /// Pentium III 1GHz, 512MB, Asus V7700 64MB AGP, SB Live!
Reply 64 of 100, by HandOfFate
As promised, the Python script that I made for updating the LAUNCHBX.TXT database.
I'm happy with how much it is finding but it has been completely designed for my purposes, so I wouldn't be surprised if you run into a dozen problems. But I will see what I can do in that case 😀
What's required:
* Linux or something similar (maybe it will even work under Windows 10's bash, who knows)
* Python 3.6+ (it's possible it will work with 3.5)
How to use it:
* Make a backup of your current LAUNCHBX.TXT
* Unpack the archive
* Run download_metadata.sh to get Launchbox's XML with game metadata
* Run
python3 import_games_dir.py LOCAL_GAME_DIR:SAME_PATH_IN_DOS Metadata.xml PATH_TO_LAUNCHBX.TXT
(don't forget to escape the '\' characters)
For example:
python3 import_games_dir.py ~/DOS/Games:C:\\GAMES Metadata.xml ~/DOS/LAUNCHBX/LAUNCHBX.TXT
In case it isn't updating existing entries in your LAUNCHBX.TXT with metadata, rename the entry by hand to the exact name in the Metadata.xml. After the entry is enriched, you can rename it back to whatever you want.
Also, don't forget to download a new Metadata.xml once in a while, because even DOS games are still being updated in there.
I hope it will be somewhat of use to anyone 😀
Reply 65 of 100, by theelf
Hi, i love this DOS launcher, *but* I use in my Windows XP laptop, to launch win32 ports of DOS games (prboom, etc)
I will love to do a native console windows port, anyone knows if the source code is public?
55.71 KiB
windows
Reply 68 of 100, by overload86
dr_st wrote on 2020-10-26, 13:11:
What's the point of a text-based launcher for Windows, when you have a built-in, feature-rich GUI?
That's like asking "What's the point of Dosbox, when you can play Doom Eternal and Horizon Zero Dawn?"
Have you seen his setup? He is blending Windows 95 and 3.11 aesthetics and it looks very clean. I would honestly prefer a DOS interface for my DOS gaming, too.
Reply 69 of 100, by dr_st
overload86 wrote on 2020-10-28, 11:49:
Sorry, that's a flawed analogy. Your example is about playing different games. Here we are talking about using a text-based launcher to run the same Win32-native applications that you can run using the built-in shortcut (.LNK) feature of Windows. To this I don't see the point, other than, well, aesthetics. And when it comes to aesthetics - to each his own. 😀
My understanding was that theelf's question was not about a DOS interface for DOS games (which I prefer too, although I use a different menu myself), but a DOS-style launcher for Windows games.
Reply 70 of 100, by overload86
dr_st wrote on 2020-10-28, 13:09:
Sorry, that's a flawed analogy. Your example is about playing different games. Here we are talking about using a text-based laun […]
Yeah, but again: have you looked at his screenshot? Having a DOS style launcher makes perfect sense in that context and compiling that one to run on Windows XP natively might be a real possibility, so him asking is not unreasonable, I think.
But if that is not possible you can always simply start your dosbox from a shortcut and autoexec the DOS Launcher there.
Reply 71 of 100, by MrD
I'm using this a lot on my DOS computer now. 😀 I used to use Glance but requiring the mouse to edit items and too many fiddly stages and being unable to sort/move buttons made me put Glance away for the first time in 25 years.
I've noticed a bug, though: If you're on the main game list, say ABCDEF, then delete item B, then move to item D and try to delete it, it'll ask if you want to delete item E despite the cursor being on D. It's a bit concerning. 😀
Also, when you have a game with an ampersand in the title, it's treated as an accelerator for captions, so it'll ask if you want to delete 'Amulets Armor' instead of 'Amulets & Armor'.
Edit - Hehe just noticed that you put CD required or CD music in brackets in the title as well. 😀 I also use the Status for this.
Reply 72 of 100, by MisterEd
Thanks for an awesome DOS menu. Recently acquired a 486 DX4 100 and wanted to have it run DOS and Windows 3.11 but also be easy for people to use at an upcoming retro gaming party.
One issue I did encounter was returning to the launcher from Alley Cat - https://en.wikipedia.org/wiki/Alley_Cat_(video_game). It is the only old CGA game I have tried to run so far. The game launches without issues and when returning to the launcher it complains about an invalid video mode and the screen is filled with bright coloured text blocks.
Typing in CLS and then LAUNCHER gets me back to the menu but something about the video mode doesn't allow it to return automatically. I have an ET4000 graphics card.
Reply 73 of 100, by msaraiva
MisterEd wrote on 2020-11-25, 03:42:
Try running Alley Cat from a batch file and executing the attached program after the main game. If you don't wanna use an executable from some random dude on the internet, here's the source:
MOV AX,0003h
INT 10h
MOV AX,4C00h
INT 21h
You can compile the code above with NASM, for example All it does is set the video mode to the default MS-DOS one, which is 80x25 16 color (last two digits of the first line - 03, in this case). Here's a list of all the possible modes:
00: 40x25 Black and White text (CGA,EGA,MCGA,VGA)
01: 40x25 16 color text (CGA,EGA,MCGA,VGA)
02: 80x25 16 shades of gray text (CGA,EGA,MCGA,VGA)
03: 80x25 16 color text (CGA,EGA,MCGA,VGA)
04: 320x200 4 color graphics (CGA,EGA,MCGA,VGA)
05: 320x200 4 color graphics (CGA,EGA,MCGA,VGA)
06: 640x200 B/W graphics (CGA,EGA,MCGA,VGA)
07: 80x25 Monochrome text (MDA,HERC,EGA,VGA)
08: 160x200 16 color graphics (PCjr)
09: 320x200 16 color graphics (PCjr)
0A: 640x200 4 color graphics (PCjr)
0D: 320x200 16 color graphics (EGA,VGA)
0E: 640x200 16 color graphics (EGA,VGA)
0F: 640x350 Monochrome graphics (EGA,VGA)
10: 640x350 16 color graphics (EGA or VGA with 128K)
640x350 4 color graphics (64K EGA)
11: 640x480 B/W graphics (MCGA,VGA)
12: 640x480 16 color graphics (VGA)
13: 320x200 256 color graphics (MCGA,VGA)
    MODE03.EXE
    10 Bytes
    121 downloads
Reply 75 of 100, by MisterEd
msaraiva wrote on 2020-11-25, 20:44:
Awesome, thanks. I will give that a try tonight. I thought there might be some DOS command I had forgotten that would do similar.
Reply 76 of 100, by Shreddoc
MisterEd wrote on 2020-12-15, 05:18:
I have a vague old memory of a DOS command that would bring back the default display mode under certain circumstances. Maybe a variant of MODE - "MODE CO80" (as in "color, eighty chars"), I think.
It could be typed blind when certain gamequits garbled your screen, and (if you were lucky / game dependent) it would restore the standard dosprompt display mode of Color 80x40 chars.
<sigh> - re: vague old memory - at what exact point did the 90's become "several decades ago", grrr argh?? 😀
11:59:59 December 31 2019
Reply 77 of 100, by MisterEd
Shreddoc wrote on 2020-12-15, 07:59:
That was it. I created a batch file as suggested and called MODE 80 after the game had ended (once I remembered the undocumented command to quit Alleycat) and it returned to the launcher without issues.
Reply 78 of 100, by Peter Swinkels
I had the same issue when I wrote my own menu program to launch stuff. Alley Cat is a pretty decent game but is also one of those programs that doesn't clean up after itself properly. I think it originally was a game that could be booted without an os.
Do not read if you don't like attention seeking self-advertisements!
Did you read it anyway? Well, you can find all sorts of stuff I made using various programming languages over here:
https://github.com/peterswinkels
Reply 79 of 100, by walterg74
Peter Swinkels wrote on 2020-12-16, 08:45:
Yep, there is a booter version of it. You can find it in REMOVED.
