First post, by KJanos1396
Hello Collectors!
We (me and friends) want to share the power supply "schematic" for an vintage xt motherboard SANYO SPC-400D.
This motherboard is very rare and using 7 pin non standard power connector.
We grabbed motherboard one year ago from junkyard without power supply and we could not find anything on the Internet..🙁
And we have forgotten it all the time.
Until ...now.😀
A few weeks ago we buy power supply from collector and motherboard is working perfectly.
After we have a power supply we can measure voltage and share the result.😀
If you have same motherboard without power supply don`t panic,you can use standard power supply voltages.
Pictures attached.
Motherboard and connector:
144.08 KiB
138.58 KiB
137.56 KiB
And "Schematic":
291.59 KiB
Cheers.
KJanos1396 and Petibá.
Reply 2 of 3, by Jo22
KJanos1396 wrote:
Hello Collectors!
That's the spirit! Thank you very much! 😀
Reply 3 of 3, by derSammler
While this is great, it would have been so easy to find out which voltages go to which pins without having a working PSU, since it's known where the voltages are used on the ISA slots:
B01 GND
B03 +5V
B06 -5V
B07 -12V
B09 +12V
One minute with a continuity tester and you have it.
