First post, by ab0tj
Hey guys,
I'm wrapping up some things right now so I'll actually have some free time soon. So I've been thinking about my next project. Would anyone be interested in a AY-3-8910/YM2149 based ISA sound card? I know there aren't any DOS games that support it directly right now, but there's also quite a few talented programmers that might be able to make use of it in DOS. It would make some good chiptune type sounds...
Thoughts?
Reply 1 of 18, by dreamblaster
yeah this is in the pipeline (an LPT version ),
but many other projects before it,
I first want to implement soundchips that ARE supported by games (makes more sense),
so it will take a long time until i get to it.
New X2GS TE & X16GS sound card : https://www.serdashop.com/X2GS-TE ,
Thanks for your support !
Reply 2 of 18, by ab0tj
If there is interest, nothing wrong with having both an ISA and LPT version. Anyone who programs for it could support both.
Reply 3 of 18, by keropi
I think the lack of PC software to support that great sounding device will be a big problem... I really like how it sounds on the CPC
Reply 4 of 18, by dreamblaster
yeah the only application I could think of, is to run an emulator on PC, and use a real soundchip. (so make a driver for the emulator).
Reply 5 of 18, by Jo22
Oh well, I believe the MSX scene did such things even though there were no actual games (I'm no MSX owner, though). 😀
The MoonSound, for example, was made by hobbyists in the mid-90s, long after the MSX platform was considered dead.
That nifty little card was based around an OPL4 chip and got some interesting tracker programs.
Personally, I find the idea of ab0tj interesting.
There's something to it having a chiptune player/composer running
on old PCs running DOS, CP/M or even GEM/Win1.x. 😉
https://en.wikipedia.org/wiki/Moonsound
A few sample videos..
https://youtu.be/fGhML7YmmdQ
https://youtu.be/Dvv4GNFh8g4
https://youtu.be/2Wwhof9z8yI
https://youtu.be/tPLXPswbj6A
https://youtu.be/USHdUqrftPQ
Edit: The Covox Sound Master did also use a AY-3-8910/AY8930 PSG.
Maybe "we" can make the new design compatible to that ?
So we could have at least a little game support. 😀
http://nerdlypleasures.blogspot.de/2014/09/th … nd-devices.html
Reply 6 of 18, by keropi
Yeah I've known of that opl4 board and it is really amazing.
Not trying to ditch anything here, just stating that obvious lack of software. I'd love to see something working with it.
Reply 7 of 18, by Jo22
No, no, what you said was alright and the point was absolutely valid, too. 😅
My reply was no critique- I just wanted to note that there's amazing music that could be played on our old hardware.
Or created. For a musican/artist looking for inspiration, it would perhaps mean a lot to put him-/herself in times long gone.
The experience or ambience of working with, say, an IBM 5150, would be quite different than doing the composing on a modern day iPad or all-in-one PC.
Edit: Some of the better AY-3-8910 songs that I have found..
https://youtu.be/nK2vpUE4lSM , https://youtu.be/IVqZ1ev9BC8
https://youtu.be/-l5JkPzXsUs , https://youtu.be/hZ1jaZLnAK0 (2x Monkey Island)
Reply 8 of 18, by chartreuse
Wouldn't be too difficult, if it's a YM2149 running with the clock at 4MHz (I think), to write a simple YM music format player. Since the YM format is basically just a compressed register dump. Would at least let it be somewhat useful by being able to play Atari ST music files.
Reply 9 of 18, by Scali
Jo22 wrote:
Edit: The Covox Sound Master did also use a AY-3-8910/AY8930 PSG. Maybe "we" can make the new design compatible to that ? […]
Yea, although I doubt that MobyGames is very accurate on that: www.mobygames.com/attribute/sheet/attributeId,80/
I would expect only a handful of games to support it, not 164.
Reply 10 of 18, by Scali
Judging from the pictures, there is no crystal/oscillator or anything on the Covox Sound Master. That means there is no way to generate a 4 MHz clock signal. I suspect it divides the 14.32 MHz NTSC clock on the ISA bus to get 3.57 MHz, same as various other sound interfaces on PC do, such as the SN76489 in PCjr/Tandy, and the AdLib.
Even so, it might not be too difficult to take a 4 MHz YM file, and adjust all frequency commands for 3.57 MHz.
Reply 11 of 18, by Tronix
Nice idea to make YM2149 ISA soundcard. For some reason i build my LPT version back in 2014 (USB connector only to get 5V power from USB):
Then in 2015 i make USB version (based on pic16f microcontroller) :
Demo-records from this devices you can find at https://soundcloud.com/tronix286
As for supporting games, i thing it is possible to modify Miles Sound System driver, as it was done for a sound cards Innovation SSI-2001 MIDI driver and Creative Music System (CMS) / Game Blaster MIDI drivers
https://github.com/Tronix286/
Reply 12 of 18, by carlostex
Well have a Covox Sound Master in the works. Fagear, did a lot already checking the traces from Covox Sound Master pictures. shock__ will work with motorumi to reverse engineer the CSM, but only after he finishes ARGUS.
As far as game support it should bem similar to the Innovation SSI-2001, maybe around 12 games support it. Most games that claim Covox Sound Master support are actually referring to the Covox Sound Master II which uses a YM3812 OPL2 chip.
Reply 13 of 18, by chartreuse
Probably could be done real time in the player. YM is just a 50Hz register dump format. Just would need to take the values going to the frequency registers and do some scaling (~ -10.75%) on them.
Reply 14 of 18, by matze79
The Covox Soundmaster also has a DAC right ?
Reply 16 of 18, by matze79
Hm is there something special on the Covox Soundmaster ? except for DAC ?
i try to connect the AY to ISA Bus and simply hook it to the soundmaster i/o address.
lets see what happens..
Reply 17 of 18, by FreddyV
Hi,
The PicoMEM Now support MindScape Music Board emulation (Dual AY-3-8910) 😀
The attachment CONSIDER.mp3 is no longer available
Reply 18 of 18, by carlostex
Awesome! Now we need a Audio Interface Library 2 driver and driver for Sierra SCI games 😀
