First post, by CrossBow777
- Member
So I've had Black Thorne for a while and it seems to work fine under Dosbox. I recently picked up a Roland MT-200. Basically an SC-55 sound module with a disk drive to play midi files directly on it. I have it connected to my modern day PC through a Roland UMONE mk II usb to Midi cable. So far, everything else that supports general midi or sound canvas has worked excellent! But when getting black thorne setup to use Gen midi for music and loading up the game. It just hangs on the OPL2 driver section loading up. I've other games that use the same driver for their sound and they seem to work fine but this is the first I've encountered with black thorne doing this.
Anyone seen it do this before? I did check the other sound settings wherein I use the SB emulation in dosbox for most other stuff. So I have everything working that I've currently tested minus this one game.
any ideas are greatly appreciated!
