First post, by Zuon
So I recently acquired an old machine with a 750mhz Pentium III, 256mb of RAM (expandable to 512mb) and an ATI Rage Mobility 128 Pro. Surprisingly when I tried the original Max Payne on it, it ran beautifully at medium details at 800x600, and even smoother at 640x480. My question is, are there any other DX8 or DX9 based games that can still run on older DX7 hardware? If so, what are some of them? I'd love to test this laptop out some more.
Reply 1 of 7, by weldum
Your graphic card is DirectX 6 capable, meaning it has no support for Hardware TnL, having said that, i know that these games should run (given enough VRAM and/or AGP aperture):
Max Payne
Max Payne 2
GTA 3 (12MB VRAM)
GTA Vice City (16MB VRAM)
GTA San Andreas (64MB VRAM)
Need For speed all up to Most Wanted (2005)
Unreal, Unreal 2, Unreal Tournament, Unreal Tournament 2003, Unreal Tournament 2004
Quake 1 up to 3
Counter Strike
Every Source Engine based game (only in older pre 2006 versions of the engine)
Mafia
Serious Sam The First Encounter/Second Encounter
Warcraft 3 - Frozen Throne
Shadow Ops Red Mercury
Older 3D based Worms games
Later I will do a post about a similar machine but with a P3 900MHz, 384MB of RAM and a Savage IX with 8MB of SGRAM, comparing to a Duron 900MHZ with a Rage Pro Turbo 8MB, and I will use all of the games menctioned in the list.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 3 of 7, by Stiletto
Moved.
do the Fandango!" - Queen
Stiletto
Reply 4 of 7, by Zuon
collector wrote:
Note that this subforum is for older Windows games on newer systems. Old hardware related questions should be asked in Marvin. Marvin, the Paranoid Android
For some reason this doesn't make sense to me. My question was about games, not on hardware advice. But I supposed it is a bit of a gray topic. I'll accept it.
Reply 5 of 7, by Stiletto
Marvin has a specific subforum for posts like this, called "Software".
Max Payne was designed to be run on Windows 95, Windows 98, Windows 98 Second Edition, and Windows ME. (Windows XP was tested, but not officially supported, shortly after the game was released in 2001.)
If your current host operating system for the game is one of the above, then, basically, your topic belongs in Marvin -> Software. (Windows XP is kinda a borderline call.)
If your current host operating system for the game is (possibly Windows XP), Windows Vista, Windows 7, Windows 8, Windows 8.1, or Windows 10, then your topic belongs in Windows, since that forum is specifically for running old Windows games natively on newer operating systems than the game shipped with support for.
Stiletto
Reply 6 of 7, by leileilol
Rmemeber there's plenty of games that would support DX6/7 because of how ubiquitous the GF2MX and GF4MX cards were at one point in 2002-2005, the GF4MX being DX7 at best, and DX7 being pretty much a T&L+Cubemaps over DX6 (apart from the huge backend rework, this is a gross oversimplification)
Early games that started requiring pixel shaders tend to be of the AAA kind that had Xbox ports.
Reply 7 of 7, by schmatzler
Independence War 2: Edge of Chaos is such an example. It only uses DirectX 8 for its online features and force-installs it during the setup.
But if you remove it with DirectX Buster and reinstall DX7, the singleplayer mode works fine. 😀
