First post, by appiah4
- l33t++
I can get an M10000 for a reasonable price to set up an ultra portable Win9x PC but how good is it for this role? Is it a useful hardware to have?
https://www.viatech.com/en/support/eol/epia-m-eol/
There should be drivers for the integrated devices. As for how useful it would be - what do you want to do with it?
wrote:There should be drivers for the integrated devices. As for how useful it would be - what do you want to do with it?
Win9x gaming up to 1999 is what I had in mind. I don't know if the chipset has DOS compatibility (my initial research suggest that VT8235 is only AC97 compliant, so no legacy SB drivers..) but the onboard VGA seems to be a Savage4 which should be more than fine for Win9x gaming up to that era? I want to just drop it into a m-ITX VESA case and haul it around with me to play things like Quake 3, Freespace 2 etc. on the go.
I have an EPIA-CN which is a little bit newer. I can try installing Windows 98 on it if that helps?
I've never actually used it for anything myself, bought it for a project that never materialised.
wrote:I have an EPIA-CN which is a little bit newer. I can try installing Windows 98 on it if that helps?
Don't go through the hassle for my sake. 😀
I'm considering putting this inside a mini-ITX case I have with an external 60W 12V Power Supply, I believe system consumption should be fine with this setup? I'll be using a 2.5" laptop hard drive with it..
wrote:Don't go through the hassle for my sake. 😀
If I do it it'll be tomorrow night, mainly for my own interest. 😀
wrote:I have with an external 60W 12V Power Supply, I believe system consumption should be fine with this setup?
In the manual they say a "90 to 120W ATX power supply is ample for even the heaviest of multimedia system applications".
But then they have a graph showing the utilisation hovering around 30W during DVD playback, so you might be able to get away with 60W? If you already have it, I'd say give it a shot.
wrote:wrote:Don't go through the hassle for my sake. 😀
I would be more than interested in hearing how the thing fares as a Win9x gaming rig then 😀
wrote:wrote:I have with an external 60W 12V Power Supply, I believe system consumption should be fine with this setup?
I have the case but not the board, which would set me back some $30 to obtain with the C3 1GHz CPU on it, but no RAM.. Not a bad deal really, might as well just get it and try it out.
wrote:wrote:There should be drivers for the integrated devices. As for how useful it would be - what do you want to do with it?
Bear in mind that an Epia performs much slower than an equivalently-clocked P3. The CPU would be at best comparable to a 500MHz P3. But for gaming video is likely to be your biggest issue.
It's not the drivers, it's SB legacy BIOS support you need. I have a very similar Transmeta Crusoe system with that southbridge and I certainly don't have it.
Savage4 is not great but should be able to do something - but the Achilles' heel here is the UMA - that Savage4 and the CPU share - limited - memory bandwidth. Expect 30-50% performance drop vs the same CPU with a non-integrated Savage 4. So you're probably going to see performance like a P2-266 with dedicated Savage4. That doesn't sound like fun Q3A or Freespace 2 gaming...
I used to have an EPIA-V with 533MHz C3 CPU. The drivers on the VIA site are marked for WinXP but also installed properly on Win98SE; might be the same situation for the EPIA-M series. It was very slow overall... SpeedSys had it performing little better than a P-II 233. The 1GHz chip on the EPIA-M should fare significantly better, but I doubt it'll stand a chance against even a 600MHz P-III.
Check the capacitors first - the original EPIA's used very good Sanyo caps, the -M's... didn't. (GSC IIRC)
Performance in the PIII-533 to PIII-733 range is exactly what I need so I will be OK with that. Sad to hear about UniChrome not being as fast as a Savage4 but I guess most games should still be playablet at 30+fps if resolution is 640x480 or 800x600? I wish I could find some decent benchmarks.
EDIT: Ok so I appear to have found a decent review here:
https://www.mini-itx.com/reviews/nehemiah/
I'm ok with this.
The board arrived yesterday, I am hoping to put it inside an mITX barebone case with a 60W external power supply this week.
I plan to install WinMe on it simply because how dependent it will be on USB2.0 support, and because it lacks any DOS audio compatibility anyway. I will give my impressions on how good a retro gaming system it is. What I hope to get out of this project is a portable system I can play Quake 2/3, Freespace 1/2, Homeworld, System Shock 2, C&C/RA/TS, Descent 3, Age of Empires 2, Might & Magic VI, Baldur's Gate, Torment, X-Wing CS, X-Wing Alliance, Thief etc.
I absolutely did NOT need this system, so I have no idea why I am doing this, but let's just do it for the good of all of us, except the ones who are dead, I guess.
Excited to see what this little fella can do. You can always drop in a replacement PCI sound card or faster video card depending on what you need.
wrote:Excited to see what this little fella can do. You can always drop in a replacement PCI sound card or faster video card depending on what you need.
The case I will use is super tiny and has no expansion room but maybe later I can move it to another case with an ESS Solo-1 for DOS support.. for now priority is portable Win9x gaming..
I used to use these boards a few years ago. They are very stable and work well for embedded applications.
Having said that, happycube is correct in that the -M boards used bad caps.
I also found that some EPIA models were very lacking in driver support for non-XP OSes.
Upon visual inspection I can't find any on my board that appear to be faulty, and it POSTs fine, so I won't bother with recapping just yet.. I do believe everything that comes with the board has Win9x drivers by VIA, but I will probably have to hunt them down manually. I could go with 1GB and XP I guess, but I'm thinking I could have issues with early Win9x games that way?
I have the epia 800 and it does have an option for enabling sb compatibility in the bios. I use it with a pci v3, it runs equivalent to a PII 400.
Minor update. The EPIA MB did not fit in the slim modern mITX case I had so I will have to try it in a mATX case which I was going to use for an AM3 build. That means it will be temporary but I can now use a PCI video or sound card in the build.
So.. Which do you think is the better idea? Drop in a high end PCI VGA like the Radeon 9250 or a nice PCI sound card with Legacy SB support such as a Solo-1 or an FM-801?
