First post, by oeuvre
Gutted an HP Compaq dc7600 mid tower. Standard ATX layout. Front panel was standard as well! Even the power and HD LEDs work.
Rosewill Glacier 700W Modular power supply
Gigabyte Z170HD3P motherboard
Intel i7 6700K
Zalman cooler
Arctic F9 rear fan
32GB RAM
Samsung 950 Pro 256GB M.2 SSD
Seagate 2TB 7200RPM hard drive
DVD/RW drive
5.25" USB 3.0 front panel with 3.5/2.5 bay
NVIDIA GeForce GTX1060 6GB video card
So the original power supply is slightly larger than standard ATX but the screw holes aligned fine for the first part. Addon cards do not require a screwdriver for installation.
Side view of the interior
Hid the hard drive in there since the SATA power connector was jutting out and preventing the case from properly closing.
Roomy!
Side panel. The black frame is removable so I spray painted it black to make it look much better.
Other side. Missing one of the rubber feet.
Before the spray paint
In action!
Front panel USB 2.0 + audio jacks work fine
specs + temps
Reply 1 of 7, by KCompRoom2000
Really cool! I always enjoy the idea of reusing older computer cases for newer hardware builds, especially cases from OEM P4-era systems like your HP DC7600. Maybe one of these days I'll get around to doing something similar with a midnight-grey Dell Dimension case.
Reply 2 of 7, by oeuvre
You mean like those Dimension 8200 cases? I think it can be done since they're mATX layout
Reply 3 of 7, by greasemonkey90s
very clean i like it
Reply 4 of 7, by chinny22
HP's round that era did have nice cases both in looks and design, Good to know the front panel connectors are all standard, that's usually the main negative
Reply 5 of 7, by oeuvre
They were also quite easy to work with. Opening it is a breeze, toolless access for PCIe/PCI slots, decent amount of drive bays. Nice to have front USB 2.0 + 3.0 + audio again.
Reply 6 of 7, by kolmio
Is it possible to rotate optical drive bays to make it into a desktop position?
Now I know it's just drives itself can be inserted either way 😁
Windows 95 | Chaintech 486SPM M102.A | AMD-X5-133ADW or Am486DX4-100 | 48MB SIMM FPM | ATI Rage 3D II+DVD | CT4100 | 8GB CF
Windows 98 | Acorp 6BX86 | Pentium III 900, slotket | 512MB PC100 | Radeon 9250 | SoundForte SF16-FMI-03 | 64GB MicroSD
Reply 7 of 7, by kolmio
oeuvre wrote on 2018-02-22, 20:44:
How in the world you managed to take it apart?
I see that black outer frame wraps inner chassis in such a way that it can't be extracted. I didn't try to do it though.
