First post, by keropi
Hiya!
Several years ago I was given this Elite FX-3000 motherboard with a missing BIOS rom and oscillator (oscillator was transplanted to some amiga accelerator or something along these lines IIRC). I was told the mobo was fine, it just became a donor for the xtal/eprom 🤣
So I thought it was high time to see if it actually works. I have a 486SX25 cpu I'd like to try with it but I am not sure what xtal I need... I *think* I need a 50mhz for a sx25 cpu (and a 66mhz for a dx2-66) right?
Also anyone has an image of the "486DX ISA BIOS" for this mobo?
Lastly, about that LOCAL1 slot there is a source on the net calling it "32bit MCA Local Bus slots" and there is a report here that it's not actually a VLB slot and it killed a vlb vga. Any idea what this slot actually is?
Thanks in advance for any info/help!
edit:
hmm this ebay auction that has a mobo like mine with the 486 socked, "vlb" populated and same "486DX ISA BIOS" sticker uses a 25mhz crystal: https://www.ebay.com/itm/172461365155
maybe when the 486 cpu is installed you need the same xtal mhz as the fsb
Reply 2 of 3, by keropi
BastlerMike wrote:
There is already a thread about this mainboard
Re: FX-3000 motherboard thread
I have seen that but the BIOS you posted has this string: 40-0100-001131-00101111-111192-UMC480
Compare it to Phil's pics here and you'll see it's quite different: https://www.philscomputerlab.com/fx-3000.html
Reply 3 of 3, by keropi
allright, Phil dumped the BIOS (thanks!) - I am attaching it here just in case anyone else needs it
    Phils-FX-3000-BIOS.zip
    41.71 KiB
    63 downloads
