First post, by MKT_Gundam
Can i use a real SC55 on x68K emulator?
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 1 of 3, by Arbee
Yes, MAME supports MIDI output from the X68000 driver to a real SC55 or compatible, as long as it's a recent-ish version of MAME.
https://www.youtube.com/watch?v=MTsd3n-DUwY shows Dracula X playing from MAME to an iPad running the official Roland SC55 emulator, but it works with real hardware too.
Reply 2 of 3, by CrossBow777
I've gotten the x68k emulator itself running without issues through my MT-200. Not an actual SC-55 but as long as long as I make sure that my UM-ONE mk2 is the primary MIDI device in windows, the emu will see the MT-200 as a valid SC device (Because it is...) and use it just fine. I've not tested the emu with my mt-32 yet, but I'd image it would work just as well as long as I select my mt-32 as the active audio device on my AV switch.
Midi Modules: MT-32 (OLD), MT-200, MT-90, SD-20
