Socket 7 Sleeper
First post, by Formulator
This was an unusual system to obtain. What appeared to be a IBM-AT in a tower enclosure turned out to be a heavily upgraded Socket 7 system. System was used in an auto restoration shop. Once cleaned up it now seems to work fine.
Will use the tower enclosure with a genuine AT system.
PCChips M525/ESS Audiodrive 1868F/Trident TWN7389 PCI
Dual Boot OS/2 Warp 4/Windows 95.
The attachment IMG_1970s.jpg is no longer available
The attachment IMG_2027s.jpg is no longer available
The attachment IMG_2046s.jpg is no longer available
The attachment IMG_2049s.jpg is no longer available
Reply 2 of 11, by Jo22
^ +1
And for OS/2 Warp 4, too. ^_^
Reply 3 of 11, by Formulator
Nothing special about the sound/video hardware, but I do like the ES1868 as a DOS soundcard.
It was apparent the original used had user OS/2 as their primary OS. After working with it for a short time, I lament not using it more at the time it was released.
The attachment IMG_2028s.jpg is no longer available
The attachment IMG_2029s.jpg is no longer available
Reply 4 of 11, by candle_86
I bet you it started as an IBM AT and instead of buying an entire computer a shop just gutted the old AT tower and installed the socket 7 as an upgrade
Reply 5 of 11, by keropi
I like it 😀
Also I had witnessed back in the day a local computer shop doing exactly what candle_86 describes: a p75 setup inside a XT case - I still remember the comments they made during assembly saying that this was theft-proof since no one would steal a XT at that point of time 🤣
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
Reply 6 of 11, by candle_86
keropi wrote:
I like it 😀
I saw it with an old system as well, can't remember the brand anymore but was advertised as 486SX-25, upon opening it instead was found an ASUS P5A and a K6-2 450 with 256mb of ram. Sadly I tossed it way back in the day, i think 2003/2004
Reply 7 of 11, by dr.ido
I wonder if this is thing with auto shops? When cleaning out an auto shop I found a flip top baby AT desktop case that other than the presence of a CDROM and 3.5" floppy drive I would have expected it to be an XT or 286 system. It turned out to be a Pentium 75 with 32MB ram and a 1GB HDD running Windows 98. There was no soundcard installed, I guess the CDROM drive was purely for parts catalogs supplied on CDs. I suspect the owner had the case since new when it was originally an XT or 286 system as buried in the office I also found a couple of 5.25" floppy drives and a few boxes of floppies. Clearing another part of the building I found the original box for the 14" VGA monitor he was using which probably was from a previous upgrade to a 386 - found the box for the motherboard, but no other parts. Same shop also had some kind of alignment machine that was controlled by a BBC master computer - found the manuals, floppies and floppy drive. Unfortunately the system was nowhere to be found.
Reply 8 of 11, by Munx
I dont remember the full specs, but our first family PC had 32 megs of ram, 200MB hard drive, ran Windows 3.11 and judging by how some games ran too fast, a 486 CPU. It was inside a case that looked nearly identical to an IBM PC AT with a big red flip-switch on the side.
My builds!
The Underdog - The budget K6
Reply 9 of 11, by appiah4
Anything that comes with OS/2 installed is golden in my book.
Reply 10 of 11, by Disruptor
I've got a K6-2+ 533 @ 400 running in a case like this (256 RAM).
I don't want to OC my S7 motherboard.
At least my board supports 2.0 V
Formulator's motherboard has a flat area populated with L2 and northbridge. RAM slots and CPU socket are even well placed for an AT case like this.
The problem with AT cases is that there is an internal full size bay for HDD so there is even no space for CPU coolers in that corner.
If you know AT SS7 boards having a flat area in that corner, please let me know.
Reply 11 of 11, by amadeus777999
Very nice system and that ESS is a pretty handy card.
