First post, by candle_86
Ok So my Pentium III struggles are ongoing so parts list isn't finalized yet, but the case is sanded and ready for paint, and here is what ive got for now.
Case: Deer (unknown model
GPU: Quadro FX3000 (Will flash to FX5900Ultra)
Audio: Soundblaster Live CT4760
USB 2.0: VIA VT6212L PCI Card
SATA: SIL 3114 PCI Card (will use even with AMD XP If I go that route)
Unknown CPU/RAM/MOBO Combo to use
Intel D815EEA2/PEntium III 1.26/512mb PC133 (If the board will boot the PIII)
SOYO KT600 Dragon Plus/512mb DDR333/Athlon XP 1900+ If the P3 still wont do what I want.
the pictures to start with are the case tore apart, it also has blue transparent doors heavily scratched that I'm going to try plastic headlight restore on.
Case colors are (Metal all the flat dark blue, and the plastic front bezel will be going silver again, except the black insert is going blue as well, instead of silver. I'm also going to paint the metal case inside with silver to cover some imperfections and cancer I've neutralized.
Silver didn't look great, went with Green and Blue instead
    347.4 KiB
    356.79 KiB
    471.26 KiB
    860.38 KiB
Reply 3 of 20, by candle_86
Here are the parts so far I have as well as in the next post.
I also have a 500GB SATA hard drive I just have to find where i put it, but it will go on the sata controller to store all my game installers
    287.33 KiB
    385.5 KiB
    530.58 KiB
    428.24 KiB
    459.21 KiB
Reply 4 of 20, by candle_86
The stock Volcano 5 fan annoyed me, I had this fan and its must quieter, but taller. Fun fact I lost the screws when i removed the original fan 6 months ago, the new fan is attached with 2 screws intended to go into drywall anchors 🤣
    217.51 KiB
    151.66 KiB
Reply 5 of 20, by ultimate386
If your Intel board is the EEA2 U, you should be fine with the Tualatin P3. I am currently running a 1.2ghz P3 in a "U" board with no issues (also did the same thing back in the mid 2000's).
I am looking forward to seeing the custom paint work! Having done this myself, I would strongly recommend using a Rustoleum enamel paint for the larger surfaces: case and panels. It takes longer to dry, but you'll get a much nicer, more even finish. Smaller plastic pieces like face plates are fine with the acrylic paint.
AMD386/IIT387DX40, 32MB, ATi Mach64, AWE64
Compaq Prolinea 4/33, 32MB, Tseng ET4000, SB16
AMD X5, 64MB, S3 Virge/Voodoo1, AWE64
AMD K62+550, 256MB, Voodoo3, AWE64 Gold
P3 1.2Ghz, 512MB, Radeon 7500/Voodoo2 SLI, SB Live!
Reply 6 of 20, by candle_86
Its a budget issue, this paint was free, I've got a zero dollar budget on this so I've got stuff I had or was given 🤣.
Reply 7 of 20, by candle_86
Well bad news, I was cleaning up the Quadro, and I accidently cracked one of the Ram chips, its now a brick, gotta find another gpu now. To bad I don't have a rework station I'd just get replacement DDR. I do have a 6800GS I can use, but its not going to play well with older games from what I understand, and below that I have a TNT2 Ultra which is to slow so grrr 🤣
Reply 8 of 20, by ultimate386
Been there, done that, totally understand. Paint work can be fun and challenging. I have two non-computer projects I'm working on and two computers in the pipeline to get painted. Lot's of good info on Youtube!
Too bad about the Quadro 🙁
Reply 9 of 20, by candle_86
wind picked up and caused pooling of the silver paint, but ill just wet sand it agian and give it another coat
Reply 11 of 20, by candle_86
It's been raining here in texas, but I got some work done, the plastic that is pitted now has bondo, will sand this evening
    364.48 KiB
Reply 12 of 20, by slivercr
Robert B wrote:
NICE! 😁 Looking forward to the finished results of the paint job.
When you flash the FX 3000 to 5900 Ultra please post the procedure 😀
I made a recent post about this, you can read Here. Someone actually already flashed a q3000 into a 5900u following the instructions, and I flashed a q1000 into a 5800u.
Shame to hear this.
Im really eager to see the paint job! I have an old Antec case that is prime candidate for painting but I haven't really gotten to it. Your result may be the inspiration I need 😀
Outrigger: an ongoing adventure with the OR840
QuForce FX 5800: turn your Quadro into a GeForce
Reply 14 of 20, by candle_86
it's finished.
ASUS TUV4X
PIII 1.26S
512mb PC133
80GB Western Digital HDD
Quadro FX3000 (the ram is cracked but it still works fine, I don't understand 🤣)
Windows ME
Liteon DVD-RW
Liteon DVD/CD-RW
2x80mm Fan
Zip100
3.5 Floppy
Dell 250W PSU
Soundblaster Live
Unlabled 10/100 NIC with a realtek IC
VIA USB 2.0 Card
What I want to do now is take the USB 2.0 rear panel I have and make fittings in the case for those to attach in the front just to make my life easier 🤣
    481.24 KiB
    165.78 KiB
    147.03 KiB
Reply 15 of 20, by Jo22
Wow! Looks awesome to me, really shiny (that blue case matches the translucent plastic nicely)! 😎
I also like the fact that you installed a ZIP drive.
Reply 16 of 20, by ultimate386
Not bad! Any plans to paint the face plates on the Zip and cd/dvd drives?
Reply 17 of 20, by slivercr
I know its a WinME build, but the paintjob really screams XP to me!
Reply 18 of 20, by candle_86
It kinda does, doesn't it.
As for painting the bezels, I might not sure yet.
Reply 19 of 20, by candle_86
so card posts, but launching a game i get a wonderful multi colored world followed by a computer crash, and my 6800GS is now artifacting. I'm left with my older cards for now, what do yall recomend.
ATI Radeon 7000 64bit 32mb
ATI Rage 128Pro
3dfx Voodoo Banshee
