First post, by Xeo
So when I go to install Daemon Tools I get the following error:
Windows Installer was not found or is outdated.
Would you like to download and install Windows Installer 2.0?
If I click yes, it downloads InstMsiA.exe and when I try to run the file it says "InstMsiA.exe is not a valid Win32 application."
Any thoughts?
Reply 1 of 4, by skitters
Try using the InstMsiA.exe download from the Philscomputerlab website
http://www.philscomputerlab.com/daemon-tools-windows-98.html
Xeo wrote:
So when I go to install Daemon Tools I get the following error: […]
My guess is it either downloaded the wrong version (maybe a newer version that doesn't work with Windows 98) or something went wrong with the download. So try installing the version Phil used before installing Daemon-Tools.
Reply 2 of 4, by Morc
skitters wrote:
Try using the InstMsiA.exe download from the Philscomputerlab website http://www.philscomputerlab.com/daemon-tools-windows-98.ht […]
I think that it downloads Microsoft 404 site like it did to me. And yes try installing the version from Phil! https://www.philscomputerlab.com/daemon-tools … windows-98.html Link if you need.
2018 Retro Rebuild: Pentium MMX @ 166MHz, LuckyStar 5I-TX1 rev: 2.0, 32MB, Verite 2200
Reply 4 of 4, by leileilol
A modern-enough DaemonTools required is potentially undesirable.
