First post, by IMeganElisabeth
Would you trust it’s okay and safe to add files/folders/registry key to your host system if it worked perfectly well in the same bit OS? I tested in my 64 Bit Vista and it worked so am wanting to implement it into my host 64 bit Windows 10. Am just looking for personal opinions. Thanks in advance.
Reply 1 of 2, by Falcosoft
Adding files/folders even to system folders cannot do any harm if existing files are not overwritten. The same also holds for the registry. Just make sure the registry files you import only contain entries that belong to the particular software you want to migrate. Do not overwrite system settings (HKLM\System... etc.)
Website, Facebook, Youtube
Falcosoft Midi Player + Munt VSTi + BassMidi VSTi topic
Reply 2 of 2, by IMeganElisabeth
Thank you SO very much. I feel much better about making the transfer now. (:
