First post, by eoredson
I have an ancient adventure game called dndbbs (v2.7a) from 1990 and I got share.exe to load after a VER SET 7 but the program still produces an error "share.exe not installed" and I have given up on trying to load the game because it never worked. Seems to run in an XP window though.
Links to my MUD
Dndbbs executables
http://www.filegate.net/pdn/pdnbasic/DND50A2E.ZIP
Dndbbs source
http://www.filegate.net/pdn/pdnbasic/DND50A2S.ZIP
Dndbbs upgrade (10/15/2019)
http://www.filegate.net/pdn/pdnbasic/DND50A2U.ZIP
Reply 1 of 9, by eoredson
I would also like support for LFNs but that will never happen.
Links to my MUD
Dndbbs executables
Dndbbs source
Reply 2 of 9, by Dominus
Rank DOSBox Moderator
DOSBox Moderator
Use fakeshare from my Windows 3.x guide (in my signature). It will not restore share functionality but programs will not complain about share not present. However if a program uses share functionality it can lead to problems, e.g. dataloss. A game should be safe, though.
Windows 3.1x guide for DOSBox
60 seconds guide to DOSBox
Reply 3 of 9, by DosFreak
You can always boot an image, load MS-DOS on it then you can share and LFN to your hearts content or you can complain for something that will never happen.
DOSBox Compilation Guides
DosBox Feature Request Thread
PC Game Compatibility List
Running DRM games offline
Reply 4 of 9, by eoredson
Tried fakeshare and the dndbbs still did the same thing: "share.exe not installed".
LFN: "complain about something that will never happen"!?
dnd27a.zip
559.84 KiB
48 downloads
The dndbbs project which will not run in dosbox:
Links to my MUD
Dndbbs executables
Dndbbs source
Reply 5 of 9, by Dominus
DOSBox Moderator
Then it's time to boot from an image in Dosbox with that on. That should st least take care of the share problem
Reply 6 of 9, by eoredson
"boot an image" -- how do i do that?
Links to my MUD
Dndbbs executables
Dndbbs source
Reply 8 of 9, by eoredson
Ok, thanks.
Links to my MUD
Dndbbs executables
Dndbbs source
Reply 9 of 9, by eoredson
I have managed to start dndbbs with DOSbox-SVN-Daum.
Links to my MUD
Dndbbs executables
Dndbbs source
