First post, by superfury
What happens when a CPU tries to load a segment descriptor(for loading CS,DS,ES etc. or interrupts/exceptions) or interrupt descriptor from said tables while in ring 3? Will a page fault occur because CPL=3 and the tables are marked as being a supervisor page?
UniPCemu Git repository
UniPCemu for Android, Windows and PSP on itch.io
Reply 1 of 2, by BloodyCactus
a ring3 program can load any selector from the GDT. its when it accesses memory through that selector that a fault will occur (eg: write to a cpl=0 page or something).
you could just write a test and try it...
if you even think about your statement for one second you would see your assumption is wrong. Your basically saying no ring3 program could ever load a descriptor from the gdt, because gdt will always be in ring0. yet we have pmode operating systems that do just this.
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
Reply 2 of 2, by superfury
I assume the same applies to the LDT and IDT? I've already (yesterday) adjusted said loading code(loading those tables) to load as privilege level 0 instead of CPL to make e.g. JEMM386.EXE from FreeDOS able to handle it's faulting(although somehow Windows 95 setup still crashes due to other unknown CPU instruction bugs it seems).
