First post, by Phouglas
Disclaimer: I posted this like 10 years ago and never found an answer.
I have the actual Return to Zork CD, so this isn’t done abandonware edition. I create an iso. Then I run it with basically default settings, the same settings where every other game is tried works fine. But RTZ reports a i/o hard disk error at launch 8 also tried to copy the cd contents to a directory and mount that directory as a cd drive but the same issue.
Any ideas? Did someone have it they can try out?
Reply 2 of 2, by Justin1091
I also have the CD, works fine under DOS. Maybe you need to disable smartdrive. What OS are you trying to run it on? When creating an iso, make sure the volume label is the same as the original disc. Perhaps you need to play around with UDF settings when creating the ISO (not every program can do that).
