First post, by Nathanrico04
Every time I try to install SimCity 2000, I get this error, this error is at the end of the installation
    35.34 KiB
Reply 3 of 11, by Marty2dos
Such mistakes in the Dosbox get me interested.
In my build it was successfull installed.
Do you tried other Builds or the current svn?
Is this a edited Disk and exists the File "info.exe" on the disk?
    71.71 KiB
Reply 4 of 11, by Nathanrico04
Marty2dos wrote:
Such mistakes in the Dosbox get me interested. In my build it was successfull installed. […]
I tried with another build, but it gave the same error
    46.43 KiB
Reply 5 of 11, by Nathanrico04
and about the files, when I downloaded the files that come in the setup are these
    35.17 KiB
Reply 6 of 11, by gdjacobs
FYI, Abandonware isn't supported here. If you downloaded SC2k from an unofficial source, you'll have to bug them about it.
Reply 7 of 11, by bjwil1991
Got mine from GOG.com and that works, but I had to edit the batch file to rem the intro.exe command since that requires a CD, which I don't have.
Reply 8 of 11, by Marty2dos
You see? Where is info.exe ? I cant see it. The installer cant find it. Copy Error works normal 😀 Dont use any files fronm the net. use gog, ebay etc.. 😀
Reply 9 of 11, by Nathanrico04
Thanks for the help guys, I already managed to solve it, but I had to download it for
windows 3.1, but this is without sound 🙁
Reply 11 of 11, by bjwil1991
I also have the diskette version and installed that in DOSBox without issues (used an LS-240 USB SuperDrive on my Windows 7 laptop).
