MIDILPT
First post, by dreamblaster
hi,
I started work on a new project : MIDILPT :
MIDI interface on parallel port.
The idea is to make it work with SOFTMPU.
I tried to design it with through hole components only,
so it could become an easy solder kit.
The result is pretty large : approx 55mm x 55mm
Would this make sense ?
    41.14 KiB
    81.59 KiB
    71.27 KiB
    36.12 KiB
Thanks for your support !
Reply 1 of 26, by keropi
very nice!!!!
I can see it working on some retro-gaming laptops - now to create a *LPT base to have all the devices connected 😊
Reply 2 of 26, by M-HT
Would it make sense to have place on the PCB for Waveblaster header ? To either use MIDI out or Waveblaster header in case you already have DreamBlaster S1,X1, S2 or X2.
Reply 3 of 26, by Scali
So, the device would basically have a parallel-to-serial interface? Basically just a UART? And SoftMPU will provide full MPU-401 compatibility? At least for midi-out.
Reply 4 of 26, by dreamblaster
yes, that's the idea
Reply 6 of 26, by dreamblaster
redesign, using attiny to make smaller pcb, better ergonomics,
dual 3.5mm MIDI OUT (it will use 3.5mm to DIN cables), reset button..
31.8 KiB
Reply 7 of 26, by xjas
Looking good! Are those dual individual MIDI buses (i.e. 16 channels EACH) or do they just mirror each other? Being able to drive two independent multitimbral devices (i.e. a JV1010 and Yamaha XG module in my case) would be super useful.
MIDI IN would also be nice, even if it's just a pinheader on the PCB.
SoftMPU should cover DOS support well, but I'm thinking I might take a stab at writing a VXD driver for this thing (how hard could it be??) when it's further along in development. Any interest in that?
Reply 8 of 26, by Scali
Looks very nice!
I think it may especially be useful for old 386+ laptops that you can't add midi to in any other way.
It's probably also going to be cheaper than an ISA card.
Reply 9 of 26, by dreamblaster
It is just mirrored, both outputs have exactly the same signal
hmm right now, only midi out
That would be GREAT !
Reply 10 of 26, by dreamblaster
How about this feature ?
now that there's a CPU, considering to send 'all notes off' on bootup
--> this will allow to shutdown midi hanging notes by pressing reset.
Also will try to keep the interfacing compatible with S2P
--> same pinout, same drivers 😀
Reply 11 of 26, by xjas
The mirrored ports are still handy as it cuts down on the number of pass-throughs needed. If you could find a way to cram on a MIDI-IN, I can think of a bunch of applications it would be great for - using a '90s laptop as an OPL3 sound module for example, or sending a MIDI clock between two machines for sync.
Yeah a kill switch is always handy, I haven't run into a hung note in my own setup in a while but it's nice to have a clean way to zap them.
That would be sweet, that means I could essentially start with a Win9x port of the version of SoftMPU for S2P & support both devices. I found a VxD guide with some sample code online and it doesn't seem too complicated. I'm relatively new to Win9x coding though; will be a great way to expand my range. 😀
Reply 12 of 26, by dreamblaster
Yes ! I will PM you
Reply 13 of 26, by dreamblaster
MIDILPT PCB's ordered
to be continued when they arrive
Reply 14 of 26, by matze79
Why do 2 modules ? 😀 just add a wavetable header
Reply 15 of 26, by Super_Relay
the biggest problem you have with a wavetable header is that while the s2/x2 work on purely 5 volts most other wavetable cards require +12v and -12v which you can't source nearly so easily.
I made a daughter board to use the s1 with dosbox on a raspberry pi and if i wanted it to be able to use a yamaha DB50XG or even a smaller diamond wavetable card i would basically need to put an ATX power connector on it to get the voltages required to run them.
Reply 16 of 26, by dreamblaster
The PCB is ready and soldered ...
128.19 KiB
(no coding yet)
Reply 17 of 26, by matze79
No Firmware ? 😀
Reply 18 of 26, by dreamblaster
matze79 wrote:
No Firmware ? 😀
not yet
