First post, by Aglenoth
Hello Everyone !
I have bougth few laptops and the plastic feels really fragile , I have tried to unscrew few crews and plastic around those screw holes just broke apart. And I have not put any pressure on it at all.
So I have a question is there any way how to return elasticity to old plastic ?
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 1 of 6, by britain4
I’ve read about boiling plastic parts in water for a minute or two to achieve this - obviously you want to try it out on something you don’t care about first and suspend it somehow so it’s not touching the bottom of the container.
JB Weld would be good to reinforce/repair the plastic that’s already cracked.
- 486DX2-66, SoundBlaster 16, Crystal VLB graphics
- P-MMX 200MHZ, PCChips M598LMR, Voodoo 1, AD1816
- PIII 933MHz, MSI MS6119, Voodoo3 3000, SB Live!
- PIII 1400MHz, ECS P6IPAT, Voodoo5 5500, SB Audigy
Reply 2 of 6, by cyclone3d
Regular JB Weld is brittle and quite frankly sucks even for metal repair.
QuickSteel putty works way, way, way better for metal repair. It bonds better and doesn't crack like JB Weld does.
There is actual plastic repair epoxy that works very well for repairing plastic.. imagine that.
JB Weld makes some:
https://www.jbweld.com/products/plasticweld-syringe
Loctite makes some:
http://www.loctiteproducts.com/p/epxy_plstc_s … stic-Bonder.htm
Yamaha XG repository
YMF7x4 Guide
Aopen AW744L II SB-LINK
Reply 3 of 6, by yawetaG
This only works with nylon, AFAIK. With thermoplastic plastic it will lead to parts being deformed.
Reply 4 of 6, by appiah4
Plastic brittling and deformation are things you can prevent or delay but not things you can really fix after the fact.
Thankfully we are in the age of 3D printing so whatever it is that is giving you issues get it scanned and reprinted. 😎
Reply 5 of 6, by derSammler
You would need to re-add the plasticizer back that vaporizes over time to achieve that. It's certainly possible.
Reply 6 of 6, by Windows9566
I hate that the plastic on old laptops are crumbling. the plastic on the screen part of my Gateway Solo 2500 just snapped so it's now a "Half-top". the LCD panel is fine.
R5 5600X, 32 GB RAM, RTX 3060 TI, Win11
P3 600, 256 MB RAM, nVidia Riva TNT2 M64, SB Vibra 16S, Win98
PMMX 200, 128 MB RAM, S3 Virge DX, Yamaha YMF719, Win95
486DX2 66, 32 MB RAM, Trident TGUI9440, ESS ES688F, DOS
