First post, by Aglenoth
Can I ?
Pentium II 266 MHz
Diamond Voodoo Monster II 12 Mb
S3 trio 64v+ 2Mb
ESS AudioDrive 1868f
10Gb fireball HDD
256 Mb Ram
Reply 2 of 6, by Aglenoth
jesolo wrote:
Monkey Island 1 & 2 (original DOS versions) - yes.
Later versions - you need a faster PC.
Are there going to be some issues with sound or speed ?
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 3 of 6, by jheronimus
No, they're not speed-sensitive. Later versions just require Windows, though.
Pentium 166 MMX Overdrive, 32 MB RAM, Ark Logic ARK1000VL, Tekram DC-680C, Turtle Beach Tropez, Gravis Ultrasound Max
Pentium III 1000, 256 MB RAM, Matrox G400 MAX, Adaptec 19160, Yamaha YMF740B
Reply 4 of 6, by Aglenoth
Iam also concerned about zero dividing bug
Pentium II 266 MHz
S3 trio 64v+ 2Mb
10Gb fireball HDD
256 Mb Ram
Reply 5 of 6, by K1n9_Duk3
If you play with PC Speaker sound effects and music, Monkey 1 and 2 always work fine on my Pentium MMX @ 266 MHz, so they shouldn't have any trouble on a 486 @ 50 MHz. Just run the game with the parameter "i" and you're done (enter "monkey i" or "monkey2 i" at the command prompt). I know that Monkey 1 might have issues on fast systems when using AdLib/SoundBlaster audio, but haven't had any issues with Monkey 2 so far. I hacked the Monkey 1 executable myself and this fixed the divide by 0 error on my system, but you I guess you might want to use the official 486 patch for the game instead.
When running the game, you might want to force it into Adlib/SoundBlaster mode (by entering "monkey a" at the command prompt), otherwise the program might not work correctly.
Edit: I'm talking about the VGA floppy version of Monkey 1 here. I have no experience with the EGA or CD versions.
Reply 6 of 6, by Great Hierophant
The original EGA version will probably give you a Divide By Zero error with Adlib/Sound Blaster around the 386DX40 speeds.
