First post, by fsmith2003
Since I have dove into the retro PC world I have constantly heard that MS-DOS 4.0 is horrible and to stay away from it. So I have, not really knowing why. What were some of the reasons 4.0 is considered best left alone? Is 4.01 worth trying since it is said to fix the bugs? I am curious to try it on my 1990 specific build. Right now I am using Compaq 3.31 on it but have considered 4.01 since it would be more era correct.
Reply 1 of 6, by Jo22
It depends. IBM PC-DOS 4.x was better than MS-DOS 4.x.
Re: Worst cpus and worst computer builds
Reply 2 of 6, by Scali
I'm not sure if MS-DOS 4.0 is very 'era-correct'... It was a very experimental version with multitasking support, quite buggy, it even has its own wiki page: https://en.wikipedia.org/wiki/MS-DOS_4.0_(multitasking)
I haven't actually seen MS-DOS 4.0 in the wild. I believe most machines were sold with DOS 3.x, until the manufacturers moved straight to 5.0.
Reply 3 of 6, by Zup
I've only seen DOS 4.x installed on 286 computers. I guess that's not so bad, but not a good option.
I mean, if you've got a 8086 or even a 286, DOS 3.x runs better; if you've got a 386+, DOS 5 have better memory management. DOS 4 does not have the memory capabilities of DOS 5 nor the frugality of DOS 3.x so it's the best option.
I'm selling some stuff!
Reply 4 of 6, by fsmith2003
Well I tried it out and the memory optimization is horrible. So I don't see much use in it. I installed DR-DOS 5.0 instead on my 1990 build and its amazing! It really is a great alternative to MS-DOS of the time.
Reply 5 of 6, by derSammler
No, it's the other way around. Please don't mix up MS-DOS 4.01 (which was MS' fix-up of the broken IBM PC-DOS 4.00) with the crappy Multitasking MS-DOS 4.0 (aka European MS-DOS 4.0), which is way older and based on MS-DOS 2.0.
Reply 6 of 6, by BloodyCactus
4.01 just took up more memory than 3.3 for no benefit most people could see, and then 5 came out with its fancy load everything high umb which made 4.01 look even worse. 4.01 was a stopgap dos that worked with larger partitions than 3.3 could (32mb max in dos3, dos4 let this go to 2gb or something).
is it worth trying? no. 3.3 or 5/6.22 is the bookends!
--/\-[ Stu : Bloody Cactus :: http://kråketær.com :: http://mega-tokyo.com ]-/\--
