First post, by debs3759
Back in the day, I didn't have to remember my Win 95 Retails code, as a valid country code followed by any 7 digits would do the trick.
Fast forward 20 years, and I have a few copies of Win 95b with legit codes, and one copy of 95c without a code. Will 95c accept a 95b registration code? Or will random codes work, like with 95 retail? I want to use 95c on a P6 build, as it fixed some bugs that affected the P6 family chips.
I have been looking, but am unsure how to identify 95c (or OSR 2.5) from photos of CDs for sale, and most sellers are clueless. My preferred option would be to buy a legit copy with code, and use that, but as long as that doesn't appear to be an option, I need a workaround for the backup copy I have.
Reply 1 of 3, by ATauenis
Win95C should accept any OEM serial number for Win95 RTM...OSR 2.5. Retail (boxed) edition of Win95 OSR (A, B or C) never exist. Only the original Win95 RTM was in both the retail version and in the OEM version. Any other were pirate copies.
The serial numbers for Win95 OEM&Retail are easy to find in Google.
AFAIR, Win95C had the same kernel as Win95B (4.0.1111), which is not P6-optimized. The only difference from later OSR2 builds is the integrated installer of IE4. Any bug fixes and optimizations for Win95 B/C was released as updates for both releases of Windows 95.
2×Soviet ZX-Speccy, 1×MacIIsi, 1×086, 1×286, 2×386DX, 1×386SX, 2×486, 1×P54C, 7×P55C, 6×Slot1, 4×S370, 1×SlotA, 2×S462, ∞×Modern.
Reply 2 of 3, by debs3759
The serial numbers for Win95 OEM are easy to find in Google.
I know only the original Win 95 and the upgrade came in retail. I have two copies (one open and one sealed) of the upgrade. I have three OSR 2.1 oem disks with codes. I only have a pirate copy of OSR 2.5, but am looking for an original disc.
As far as I can tell, prior to OSR 2.0, MMX was flakey (hardly surprising, MMX was new!), and prior to the updates added to 2.5, P6 support was flakey. It's easier to install OSR 2.5 than an earlier version, as it needs less updates.
Reply 3 of 3, by leileilol
I can use my 95B key fine with 95C.
If it's some OEM version that changes the key format a bit you'll just have to copy the 7 numbers part of your legit key in between some easy to remember numbers.
long live PCem
Debian's fucked
