First post, by liqmat
Some of you may know I picked up an old NEC Powermate Portable APC IV system. The CMOS battery is definitely not holding charge. It is a Panasonic BR-E3:
87.42 KiB
I found only two resellers that might have one. One in Miami, but they may not carry them anymore and one in the UK. There is an Ebay seller that has them, but they don't ship to the U.S.
https://www.ebay.ie/itm/PANASONIC-BR-E3-LITHI … =item4d56533f5b
It's a 6V battery. Any ideas of what I could use if I come up dry? It has a 4-pin head.
Reply 3 of 8, by gdjacobs
The original battery is non rechargeable so there should be no back feeding current. You can check for a forward diode drop between positive and negative on the battery header with high impedance in reverse.
Reply 4 of 8, by liqmat
Well I just got word that the Miami supplier does have the original model and a third party model battery. So all is good in the world.
Actually I'll drop the links here just in case someone ever needs one. This is the only U.S. side supplier I could find that stocks these.
http://www.microbattery.com/cmos-bre3c3bca-li … m-clock-battery
http://www.microbattery.com/cmos-b9591t-lithi … m-clock-battery
Reply 5 of 8, by eisapc
Where are you located? I still have several of these NOS from an auction few years ago, but shipping from Germany may be more costly than the device.
You could use a combination of two CR123A or a CR P2P instead, because thats basically whats inside this box. The connecting wire of your battery pack usually holds a small resistor to limit current draw. You should use this for your selfbuild replacement
Reply 6 of 8, by liqmat
Thanks for the offer, but I am over the pond in the U.S. and it probably is not worth the shipping costs.
Reply 7 of 8, by liqmat
Wow!!! That Miami distributor told me it was in stock and then sent me the invoice that said backordered. When I called the next business day the order was cancelled and they never called me. Never dealing with them again.
The distributor tech support was telling me that this battery is 1.2V higher, but may work just fine. Couldn't that fry something on the motherboard of my NEC Powermate Portable though? Would 1.2V higher be an issue than the factory standard 6V battery?
Reply 8 of 8, by liqmat
Hey eisapc,
Check your PM. I might take you up on your offer since that distributor ended up not having the part. Thanks for any help.
