Running "Incoming"
First post, by DrLarrye
I found my old Incoming CD and thought I'd like to play it. I have XP on a dual boot machine (Normal system is Windows 7). After a little fiddling I got it to install and it will start but the graphics look like a Picasso painting. In researching on this site I found an entry that mentioned that NVidia drivers after 260.99 tend to screw up old games. My NVidia card (Geforce GT 630) is not supported until versions later than that. I will get a message that a supported card could not be found.
Is that it or is there something else to try?
Reply 1 of 3, by teleguy
WineD3D could work. You will probably have to select "backbuffer" as "Offscreen Rendering" mode in wined3dcfg.cpl or use 256 color compatibility mode. It might take a while for the game to load.
https://workupload.com/start/cgXnZdr
Reply 2 of 3, by skitters
Check Phil's tweak guide for Incoming
https://www.youtube.com/watch?v=3OIoJbMiCok
He's using the GOG version but most of his suggestions aren't specific to the GOG version.
Reply 3 of 3, by VirtuaIceMan
Try dgVoodoo2 with graphics card set to ATI 8500.
Also, launch the game with commandline -SCREENMODE to get a resolution selection option! There's more command line things here: http://uk.ign.com/wikis/pc-cheats/Incoming_Cheats
More tips: https://pcgamingwiki.com/wiki/Incoming
