First post, by misterjones
I'm looking at using my old P3-933MHz powered Dell GX200 to run NES, SNES, Genesis, TG16/PC Engine, and PSX games. Right now my old Matrox Mystique220 w/Rainbow Runner are in it with 98SE as the OS. I'm going to switch that to a 64MB Sapphire Radeon 7000 to get S-video out from my machine to my rear projection TV in my bedroom. Keeping 98SE is an option, but I'm starting to think XP just for newer versions of some of the emulators.
What say you?
Reply 2 of 9, by dr_st
For the things he mentioned (maybe except PSX), the old emulators are just fine and should work on either OS. If not XP, I would go with WinMe before Win98 SE, since you don't need the pure DOS mode.
Reply 3 of 9, by misterjones
Older versions of ePSXe can still run under 98SE. Not sure about the newer version(1.8+)
Reply 5 of 9, by greasemonkey90s
i have the gateway variant of this similar setup and i was torn on what to do with this machine and in the end came up with the same idea. i would go 9200/9250 maybe mine cam with Wme but i was thinking 2k for better compatibility hmm dos box on a 32in seems interesting but sounds like failure at the same time.
Reply 6 of 9, by misterjones
It's up and running with XP SP3. The single biggest reason being that this machine is not connected to the internet or even the rest of my network, so being able to use USB storage to transfer files is critical and since all of my stuff is sitting on thumb drives and hard drives all formatted with NTFS. Last time I remember attempting to mount a USB drive didn't go so well.
Plus, it's the same machine I used in these two threads:
Quake III Arena Benchmark Thread
Matrox G400/G450 Quake III Performance
Reply 7 of 9, by Jabberwock
Here is a pretty good patch for supporting USB thumb drives in 98SE.
I had used this patch with no issues on 3-4 Win98-computers.
But the author tells it can cause some problems with IEEE1394.
Right now I am using it for my PIII-1000 and P-200, both are 98SE.
nusb122.exe
88.5 KiB
213 downloads
Reply 8 of 9, by dr_st
There are newer versions of said patch:
http://www.technical-assistance.co.uk/kb/win9 … age-drivers.php
(unfortunately you can have issues if your language is not one of the listed there)
I recently used it successfully on a Win98 SE (English) version, and it worked like a charm, including USB 2.0 support via a NEC CardBus controller.
