First post, by feipoa
- l33t++
Is there any difference in image quality between the various manufactures of the original Voodoo 1? Obviously the comparison would be done on the same system with the same pass-thru cable. Has anyone looked into this? I recall reading in the forums that the Voodoo doesn't have the clearest display, but is manufacturer better than the other? Is one worse than the other?
