First post, by GabrielKnight123
Hi all, I need to buy a heatsink and fan for my AM5x86-P75 socket 3 CPU but so far I cant find any on ebay can someone please point me in the right direction
Reply 1 of 6, by debs3759
It's not cheap, but here is one. No idea where you are, so I gave you a link local to me. https://www.ebay.co.uk/itm/173032809378
Reply 2 of 6, by GabrielKnight123
Thanks Debs3759 I would like to find one with a bit more "beefy" heatsink to it as it looks like its not enough and later on I will be getting a 40mm Noctua fan for this build, that heatsink link you gave would that be enough for a AM5x86 CPU @ 133MHz?
Reply 4 of 6, by GabrielKnight123
That Ebay link is the sort im looking for as the socket 3 I have has places to clip a heatsink onto but they are not in the middle they are one the far left and right
Is there a clip on type of heatsink for my socket 3?
Reply 5 of 6, by PARKE
There was at least one type around long ago - it came with a Diamond motherboard with DX2-66 and looked like this:
100.1 KiB
Reply 6 of 6, by mcobit
Posted this in another thread also, but here you go:
https://www.thingiverse.com/thing:2459258
If you can 3D print that, it should be easy to find a cooler and fan that fits it. If you choose a higher cooler, you can make the clips longer or cut some grooves into the heatsink where they can grab on to.
