First post, by PcBytes
- l33t
So I just got a Super Socket 7 board (Azza PT-5VMD) in the worst shape ever. Missing FETs AND a voltage regulator.
I got around fixing it. Replaced all TOCON caps on it with newer (2006) OST caps (miles better than the old as hell TOCON caps that god knows if they were worth anything) and used MOSFETs from a SLOT A board I had (on which I installed better FETs, 75A 30V - these on the Pentium board are 52A 30V) and from a crappy KT133A (noname btw) MB which coincidentally used a old-style 3.3v regulator.
So far I got it to POST with only a Pentium-S CPU (cermaic version) at 120MHz.
I had a 2.2v K6-2 on hand but it's bent to all hell, the only one being a 2.4v core variant.
(and which I can't use because there's no jumper setting for the 2.4v - only the standard 2.2v and 2.8v for MMX CPUs)
Anybody know where to find an BIOS and a manual for it? I have a Voodoo 3 2000,a 8GB HDD,a LG CD-ROM and a Pentium MMX 200 and it would be a shame to not use them with it.
