First post, by root42
I just doubled my 286 performance. It turns out that JP7 on my board should be connected to a turbo switch and i was running at only 6 MHz the last months... I put a jumper on it and now it shows 12 MHz. Suddenly DoTT runs so much smoother!
The attachment 68A7899A-C667-414D-8FAA-C21B8E246385.jpeg is no longer available
YouTube and Bonus
Reply 1 of 8, by oeuvre
Reply 3 of 8, by root42
keropi wrote:
He doubled his pc performance with a simple trick intel doesn't want you to know , click the link to find more
10 different ways to overclock your retro PC! Number 6 will surprise you!
YouTube and Bonus
Reply 4 of 8, by F2bnp
hahahahahahaha
Reply 5 of 8, by Intel486dx33
What is the HOT key to enable / disable turbo mode ?
Reply 6 of 8, by root42
Well, some BIOS use Ctrl-Alt-Num+ and Num-. But it’s not generally supported.
YouTube and Bonus
Reply 7 of 8, by oeuvre
root42 wrote:
10 different ways to oeuvreclock your retro PC! Number 6 will surprise you!
Fixed.
Reply 8 of 8, by keropi
oeuvre wrote:
Fixed.
Indeed. Now it looks better.
🎵 🎧 MK1869, PCMIDI MPU , OrpheusII , Action Rewind , Megacard and 🎶GoldLib soundcard website
