First post, by BlackRogue
No one else seems to ask this.
I can't save when I'm using Dosbox!
I mean use the save function, not a "savestate"..
When I click at the save button the game turns off and the message:
"Removed from memory." Appears.
Please! HELP!
Reply 1 of 4, by Freddo
Well, what game is it that you're talking about? Kinda hard to help you when you don't give us any info.
Reply 3 of 4, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
I have a vague memory that the game saves to TEMP or TMP directory (I do not have the game here, so I do not remember to which one). Try to create them and set environment variables TEMP and TMP pointing to them (set TEMP=... etc.).
Then start the game.
Mirek
Reply 4 of 4, by crawler
its set temp=c:\temp
or whatever dir you want
