First post, by appiah4
I am currently running my K6-2 system in an Asus/ElanVitan T10 which is really neither period correct nor a good fit (in my mind) for it, but I can't really get a sense of what these systems were usually built with. K6-2 barely registered where I live, as Pentium II and Celerons basically dominated. I'd be more than happy to hear about what you think is a contemporary case or case style for a K6-2 system..
Reply 2 of 9, by SW-SSG
The Compaq I had looked like this (image shamelessly pulled from google):
69.61 KiB
IIRC it was standard mATX inside, with an SFX form factor power supply.
Reply 4 of 9, by Intel486dx33
I had this one back in the day.
917B
Reply 5 of 9, by torindkflt
Beige, possibly with grey accents (especially if it is a Compaq or HP). Also, this was about the time when case trim started to really transition from straight, squared-off lines towards more curvy designs, the Compaq case shown in SW-SSG's post being the biggest example. The iMac-inspired explosion of translucent colored case trim didn't really take hold until the tail end of the K6-2 era that I can recall, and the "black is the new beige" phase of case design was still a few years off yet.
Reply 6 of 9, by Intel486dx33
Well , My IBM Aptiva with K6-2 333mhz CPU is White with blue accents.
    179.52 KiB
    292.05 KiB
    259.23 KiB
Reply 7 of 9, by JidaiGeki
I think generic/bland AT or ATX is typical of that era, doing away with turbo buttons and MHz displays. My K6-2 in '98 was built into a pretty generic ATX case, possibly a Macase (http://www.macase.com/macase/pc-atx.htm), my PII was in a smooth-fronted AOpen HX08, and I recently bought this system - an anonymous AT mid-tower with K6-2 300 original build:
146.56 KiB
(seller's pic, I've washed it up a bit already)
Also had my eye on an ATX Super 7 machine recently, which was a generic version of the blue/white IBM Aptiva case posted above, but the seller must have deleted the listing already.
Reply 8 of 9, by shamino
K6-2 were budget builds. The authentic case will be a cramped Baby-AT carryover from a 486 or Pentium. Cheap looking, kind of dirty, maybe some blood stains, not sure if they were turning yellow yet.
After some heat issues, there will be an ugly hole cut in the front of the case with a fan bringing more air to the CPU. Okay maybe that was just me.
I think I had the same case JidaiGeki posted in that picture.
Reply 9 of 9, by Intel486dx33
I contacted AMD back in the day and they sent me some AMD k6 badges for FREE.
I still have some somewhere.
    93.53 KiB
