First post, by gladders
Hi all,
I've got the standard Live drivers running fine in W98 but Daemon Tools won't play music on games, which is a known problem I understand. Hence WDM drivers apparently being better for Daemon Tools.
So I downloaded the WDM drivers from the Vogons database, but where do I put them, exactly? I've put them in the Creative folder but nothing changes.
Thanks
Reply 1 of 9, by deleted_nk
To use the WDM drivers, you'll need to completely remove all traces of the old VXD drivers (both from the Inf folder and from device manager) and then use device manager to install the drivers.
Just a word of warning with the WDM drivers though, they do take a bit of a performance hit on 98, making things noticeably slower if you've got a slower rig.
Reply 2 of 9, by gladders
Thanks, I'll see how it goes then!
Reply 5 of 9, by gladders
My model of Live! is CT4620, which I can't find specific WDM drivers for.
I tried the CD you linked to. Letting the CD do its own thing resulted in no changes - no sound at all. Manually going through Add Hardware, I wasn't really sure where to go on the disk, but presume W9xdrv folder would be it. A ton of drivers came up, not sure which to choose, picked one at random, it complained they're not meant for this card, forced it, they installed, and I have sound but still no music in games.
Reply 6 of 9, by deleted_nk
Interesting, seems as though none of them contain WDM drivers for the 4620 on 9x, which is odd. Other than those, I'm honestly not even sure if creative ever released them for the first gen cards at all.
Reply 7 of 9, by gladders
I've discovered this: http://kxproject.com/
Do you think this might be a reasonable workaround?
Reply 8 of 9, by Stretch
No, just stay with VxD drivers. Daemon tools has an option to route the analog audio to the sound card.
Win 11 - Intel i7-1360p - 32 GB - Intel Iris Xe - ESI Maya22 USB
Reply 9 of 9, by gladders
It does? Can you show a how-to?
