First post, by InbetweenDays
I've got a 386SX-20 with the old school AMI BIOS. After replacing the dead external battery, it is giving an invalid XCMOS checksum error. Normally that's no problem - go into extended setup, write registers and exit...
However this BIOS has no extended setup option. The only menu options are exit for boot, run CMOS setup, and run diagnostics.
Any ideas on how I can fix this? I've cleared the CMOS but that didn't help. It seems some BIOSes didn't have the extended setup program, but then why give an XCMOS checksum error? 😕
Thanks,
Stu
It don't mean a thing if it ain't got 5-pin DIN.
Roland addict and founding member of the Association Of Molex Haters
Reply 2 of 4, by InbetweenDays
Yes, settings are retained just fine... there was no damage because it had an external battery fitted already (the motherboard is pristine and it doesn't look like there has ever been a battery soldered to it). No jumper for internal/external.
Anyway, an update... I found this page which describes the same issue being fixed by the setup386.com program required for C&T chipset boards. Unfortunately this doesn't seem to fix the problem because my C&T chipset differs... I have the 82C811/812/215/206 -- this would identify the most likely candidate to be the NeatSX board. I can't find my board on TULARC but the NeatSX is a very similar layout with the same chipset. Then I found this listing of utilities but the NeatSX link is dead 🙁
Reply 3 of 4, by InbetweenDays
Answering my own question... after some creative googling, I found this page which has the "C&T NEAT New Enhanced Chipset Extended CMOS Setup Utility 286, 386SX CS8281 - DOS" (Quickset utility for the NeatSX chipset).
Using that, I could configure the extended setup options such as RAM configuration, wait state etc... and voila, no more checksum error. 😀
    QUICKSET.ZIP
    11.53 KiB
    37 downloads
Reply 4 of 4, by Jed118
InbetweenDays wrote on 2018-07-06, 14:07:
Hah, you may have solved my issue with the Quickset utility that my NEAT-SX manual keeps referring to but never came with. 😁
*edit - yep, that worked! I was able to set the RAM interleave and wait states, the CPU speed (albeit I found a way to do that manually in XCMOS) and set the RAM speed. I got a bit of a performance boost on my benchmarks! 😁
What's for sale? my eBay!
