First post, by matze79
Hi,
does anyone have Information on how the Tandy DAC works ?
i read its DMA driven ? right ?
So its not so easy to implent in HW ?
i would like to make the Tandy Sound Board also DAC combatible in the future.
if it's possible, and not too complicated.
The Tandy had a DAC and a ADC for Audio Input.
So we can hookup a AD7524 to ISA Bus, and maybe a ADC804
but information is somewhat rare..
I also have no tandy machine avaible 😒
Thanks
Matthias
Reply 1 of 9, by bakemono
found an overview here: http://nerdlypleasures.blogspot.com/2015/10/t … sound-chip.html
and details here: ftp://ftp.oldskool.org/pub/tvdog/tandy1000/sound/snd_loc.txt
The DAC functionality was part of the custom PSSJ chip. It has both DMA and direct read/write (looks like the same register is used to access a joystick port as well)
Reply 2 of 9, by keenerb
Dosbox supports Tandy DAC, doesn't it? That might give you some insight if you can read the code.
Reply 3 of 9, by FreddyV
I better know how it work now.
Unfortunately, it use a DMA controller PIN that is not on the ISA Bus. (TC)
Reply 5 of 9, by matze79
Hi,
does anyone own Schematics for Tandy Machine with DAC ?
Maybe someday i could find a real tandy.
Thanks
Matthias
Reply 6 of 9, by mkarcher
FreddyV wrote on 2020-10-05, 08:24:
It is on the ISA bus, although some sources may call it differently. TC ("terminal count") aka EOP ("end of process") is on ISA pin B27.
Reply 7 of 9, by jasa1063
matze79 wrote on 2021-06-26, 11:09:
Hi, […]
Hi,
Thanks
Matthias
Here are links to the Technical Reference Manuals for the Tandy 1000 SL & TL both have a schematic section.
ftp://ftp.oldskool.org/pub/tvdog/tandy1000/do … ents/sltech.zip
ftp://ftp.oldskool.org/pub/tvdog/tandy1000/do … ents/tltech.zip
Reply 8 of 9, by FreddyV
mkarcher wrote on 2021-06-26, 13:23:
Right, so it is possible 😀
Reply 9 of 9, by FreddyV
To be compatible with the Tandy DAC, you need to add the DMA functions as well.
The Tandy DAC DMA is simple : One register containing the output frequency, one for the amplification and one to Start/Stop the output.
Plus an IRQ when at the DMA buffer end (STOP when the DMA TC signal is active as we don't send the buffer size to the DAC registers)
