First post, by robertmo
- l33t++
anyone got oled display?
It looks they got pretty cheap and pushing away traditional ones
My parents have an OLED TV and it's quite nice for watching hockey.
I think burn-in is still a real problem as is the case with plasma.
I would not use it for gaming.
Still using crappy IPS monitors here which I've been using since 2007. 🙁
Recently bought a refurb Precision 5520 w/4k glossy screen since I'm giving my parents my 5510 w/ matte 1080p screen for Christmas. Was going to do 1080 for the 5520 as well but those screens are shit so went with the 4k at 250% scaling 🙄 . The scaling issues are ridiculous.
Finally looked into peoples complaints about DOSBox with 4K (probly could have tested with DSR before) and as usual it's overblown change to overlay and change windowresolution and no more tiny screen. Think DOSBox needs a 1/2 res setting for window resolution in dosbox.conf tho.
Found this: https://www.rtings.com/tv/learn/permanent-ima … urn-in-lcd-oled
The max I spend on a monitor is $800 which is already way too much so if I went OLED it would have to be $400 (since it degrades) and not even TV screens are that cheap yet.
Supposedly the lastest OLED can last 100,000 hours which is 11+yrs. Unknown what the screen would actually look like by then but supposedly that would be 50% brightness and it won't be uniform so yeah.
wrote:Finally looked into peoples complaints about DOSBox with 4K (probly could have tested with DSR before) and as usual it's overblown change to overlay and change windowresolution and no more tiny screen. Think DOSBox needs a 1/2 res setting for window resolution in dosbox.conf tho.
DOSBox should be unproblematic for 4K users, there's just a lot of options one of them should give results close to what you want, even without resorting to fancier builds like the pixel perfect scaling one.
Add to that the various wrapper solutions for legacy Windows software allowing custom scaling options and PC gamers are really spoiled when it comes to playing their old games on new high-res displays. Console gamers are not that lucky.
wrote:I think burn-in is still a real problem as is the case with plasma.
I'm looking for a new phone now and ignoring all OLED ones for this reason.
Not so sure I would ignore a TV for the same reason though, image quality is very important in TVs and when I've gone to TV stores the OLED panels have all looked much, much better. Not because the store was specifically advertising them or had different settings for them. They just stand out, quality wise.
Have you noticed huge ghosting effect when grey objects move on black background?
wrote:Not so sure I would ignore a TV for the same reason though, image quality is very important in TVs and when I've gone to TV stores the OLED panels have all looked much, much better. Not because the store was specifically advertising them or had different settings for them. They just stand out, quality wise.
Have you looked at Sony LCD TVs like the XBR-65X900E. That's what I have now and the blacks and colours are spectacular.
And no burn in.
OLEDs produce a great picture, but from what I've heard, they're still quite fragile. Similar to early plasma displays. A friend of mine actually returned his 65" LG OLED because of noticeable burn-in (IR?) only a couple of weeks after he purchased it!
I'm still rocking my Samsung F8500 plasma, which was called the "OLED of 2013" because of how bright (and dark) it can get. It also has an awesome scaler and looks almost CRT-like displaying my old Win9x games!
"A little sign-in here, a touch of WiFi there..."
aww ye dat dell dimension XPS series
best Dells made.
I have an OLED laptop at work. While the display is quite nice, it does suffer from image retention. This has put me off getting an OLED display for personal use.
guess we'll have to wait for this to get cheaper:
https://youtu.be/LIbj6t0xS4s?t=22
was testing oled in samsung galaxy S10
(slowly scrolling text up and down)
and it has terrible ghosting just like normal TN monitors.
wrote:wrote:I think burn-in is still a real problem as is the case with plasma.
I would not use it for gaming.I'm looking for a new phone now and ignoring all OLED ones for this reason.
CRT displays were much more susceptible to burn-in and people were happy with them.
Like it or not, OLED displays are the way forward. They use less power than LCDs, have perfect black levels, faster response times, much better viewing angles... the list of advantages goes on and on. They're finally comparable to the aforementioned CRT displays from 30 years ago.
Gigabyte GA-8I915P Duo Pro | P4 530J | GF 6600 | 2GiB | 120G HDD | 2k/Vista/10/Debian
MSI MS-5169 | K6-2/350 | TNT2 M64 | 384MiB | 120G HDD | DR-/MS-DOS/NT/2k/XP/Gentoo
Dell Precision M6400 | C2D T9600 | FX 2700M | 16GiB | 128G SSD | 2k/Vista/11/Gentoo
Actually, CRTs are less susceptible to burn-in and it's by design. Also they don't accumulate dead pixels, like OLED does after 2-3 years (with total 100 days of actual use). That problem is rarely mentioned, but it's even worse than burn-in, in my opinion.
Overall, OLEDs are just as flawed as plasma screens were and we won't see complete replacement of LCDs any time soon. Maybe MicroLED will finally fix that. Until that time, LCD will remain as the most robust picture output technology to use. Panels with LED backlight are still going strong, even after 10 years of active use.
I have two OLED panels, one in my original Vita and one in my Vivobook laptop. I think they both look fantastic and I love using them. Haven't really noticed any noticeable ghosting with either, I've seen way worse ghosting on just about every other LCD panel I've ever used. That's not to say there isn't some at least to my eyes, but it certainly doesn't bother me.
I understand people's concern with image retention and burn in, and while I haven't had either long term to find out (only had the Vita for 3 years since I imported it, and laptop is fairly recent), I think the fuss over OLED's issues in that department are a little over-exaggerated . I think a lot of the complaints with OLED were over the really early displays and that notion has stuck with them ever since. With that said, OLED is probably the least ideal from a longevity standpoint if you're using it as a computer display that is going to frequently have static GUI elements left on the screen for hours. But as a screen for watching content or playing games on, I think OLED is fantastic and it's the closest I've seen a display get to the true deep blacks and color reproduction of my Trinitron monitor.
I guess only time will tell with OLED. Most Vita 1000s are still going strong and those are all about a decade old at this point. Who knows how the degradation will factor into this either since OLED is using an organic substance. What will probably kill a lot of OLED displays is their controller boards going bad, which is also true of LCDs and CRTs.
At least for now I'd say I'm in the OLED camp. I think the image quality advantage is too great for me to consider moving away from them (especially my laptop, it really is gorgeous). I would like to get some time with other technologies like Micro LED to see if it changes my opinion. But as of now, I wouldn't have any issues with recommending someone an OLED panel if they can afford it and the next screen I buy for my console gaming setup is most likely going to be OLED.
I think the QD-OLED/QLED panels show a lot of promise for computing usage for the next few years, as they sort of combine best of the both worlds and mitigate some of the issues of OLED.
I’ve had 55” OLED telly for almost five years now and no complaints so far. IQ is extremely good and so far there are no signs of wear. Granted, me and missus aren’t heavy TV users, although it has been used pretty much daily. I also rarely game on it, so your mileage may vary.
GemCookie wrote on 2023-03-20, 20:01:wrote:wrote:I think burn-in is still a real problem as is the case with plasma.
Lol no.
They were much less susceptible to burn-in and even less susceptible to uneven wear. Since this is a forum full of CRTs fans, I should note that I think CRTs are shit and I'm glad we've moved on from them, but not because of burn-in.
Also you're nearly 5 years late on this reply.
NTG2001 wrote on 2023-03-21, 04:05:I guess only time will tell with OLED. Most Vita 1000s are still going strong and those are all about a decade old at this point.
They also don't have any static UI elements. Unless you're only playing the same game all the time. That said even without static UI elements you will see another OLED wear problem on a lot of Vitas: uneven wear of RGB. My Vita has gotten a warmer color tone since I got it. Which I like, so no big loss there.
CharlieFoxtrot wrote on 2023-03-21, 07:18:I think the QD-OLED/QLED panels show a lot of promise for computing usage for the next few years, as they sort of combine best of the both worlds and mitigate some of the issues of OLED.
QD-OLED is just as crappy as classic OLED, with exception of uneven RGB wear-out - https://www.youtube.com/watch?v=my1lyUE7WVM
And QLED is a fancy naming for Mini-LED LCD technology.
OLED is not the way forward, primarily they lack the brightness to do proper HDR. Anyone who has gamed on a 1000+ nit display knows what I'm talking about. Also the other problems already mentioned. OLED is a temp tech just like plasma.
I'm not saying LCD local array and such are not temporary either, they all are, just that the future is not better OLED.
