First post, by bjwil1991
Haven't used a server OS in ages and today, I got Windows 98SE to connect to the Server 2008 Standard domain after altering changes in both OSes. However, I cannot find a way to make the profile folders the default when the drive is mapped instead of the profiles being on the client HDD to save space. Do I use the Group Policy Management Console for the profiles? I got it to work before back when I had Server 2008 R2 64-bit and Windows 7 Pro as the client, as well as Windows 98SE connected to Server 2003 Standard R2.
Reply 1 of 1, by chinny22
Problem is Windows 2000 was the first OS to truly support Group policy, earlier OS's don't natively support it so have to jump though a few hoops.
Below lists a few ways to modify the registry, if you were doing this for lots of computers you could probably force the registry change over group policy, but for 1 or 2 I'd just do it per machine.
http://www.dslreports.com/forum/r4804241-Wind … ocuments-Folder
