Got a simple Problem ^^
First post, by -Orgy-
My Problem is at the actually DOS-Box i can't write a Backslash... \ <-- This one ^^ Maybe the ALT key 2 write it is blocked oO
By the way... i cant find any language support or or Key support... i use europe keys but the dll's are 4 an american one...
Next thing is the Game Genewars... it seems that it didn't run... i use win2k maybe the backslash is the problem that it didn't work... (can'T write any mounts...) so i use "mount c c:/" instead of "mount c c:\" so the path isn't right
Reply 1 of 6, by Iron
it's been dealt in atleast 100 posts by now.. use / instead.
mount c c://
Reply 2 of 6, by Qbix
Rank DOSBox Author
DOSBox Author
well it's documented at multiple places as well as a file with the very weird name called README
So try looking there for your backslash problem.
Water flows down the stream
Reply 3 of 6, by -Orgy-
So the game Genewars didn't work...
At another game it can't creat files 'cause there is no backslash... he writes "can't create file c: /\..." so this game didn't start too.
Reply 4 of 6, by mirekluza
Rank DOSBox Moderator
DOSBox Moderator
I think that using / instead of \ works only on Windows NT/2000/XP, not on W9x.
Use another solution (switch keyboard layout in Windows) or wait for the next version.
Mirek
Reply 5 of 6, by -Orgy-
Yeah that maybe the reason... I use 2k maybe i should use DOS-Box on 98 and i try it there again... Genewars run on 95, 98 and ME 4 example it may be just a kernel and memory problem.
The only problem is... i got no drivers for my actually hardware below win 2k...
Reply 6 of 6, by Og
Sometimes Dosbox gives that message when it tries to write to a hidden file (maybe other attributes have problems too), I've seen it happen in Supaplex.
