First post, by twiz11
Or is it by case basis?
All Windows games is a tall order. Too tall, I think
not a vm but a live dvd knoppix
has nvidia and amd drivers and wine
just boot into it and play the games installed on your hard drives
If you want anywhere near good compatibility you want PCI-e passthrough and for that you need a dedicated GPU. It's also pretty complicated to set up.
That's all a dream theory until you run into mouse input issues with VMs.
wrote:That's all a dream theory until you run into mouse input issues with VMs.
No mouse input issues if you passthrough the USB port to the VM. You'll probably need a KVM. The best solution isn't cheap either.
