First post, by aardvark82
Navigating to Main --> Control Panel --> Enhanced and clicking Virtual Memory causes following error in Windows 3.11:
System Error
Divide By Zero or Overflow Error
https://imgur.com/2NjgKrZ
This happens in r4118 and later, r4113 works fine. Didn't try r4114-17 as those are not available on EmuCR.
Tested in fresh installs of Windows 3.1 and Windows for Workgroups 3.11
Reply 1 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
This is with a clean SVN build right ? (as you mentioned EmuCR)
Water flows down the stream
Reply 2 of 5, by aardvark82
Sorry, are EmuCR builds not clean?
I did compile the latest SVN snapshot with MinGW, it produces same error.
Tried the EmuCR builds to find out that r4113 is last one that works.
Reply 3 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
yeah. EmuCr is clean as far as I know.
Thanks for the report
Reply 4 of 5, by Ringding
Easily reproducible.
With svn 4114 it works. With 4115 it goes to black screen and locks hard. With 4116, division by zero is shown.
Reply 5 of 5, by Qbix
Rank DOSBox Author
DOSBox Author
Yep, ripsaw managed to reproduce and fix it. Fix is currently undergoing some testing
