IBM 5150 Mainboard repair
First post, by Predator99
...to continue this topic in the wrong thread..
Re: Bought these (retro) hardware today
stamasd wrote:
You're welcome. You should start by figuring out if the oscillator is working at all e.g. see if there is a CLK signal at the ISA slots (test between pin B20 and ground http://www.hardwarebook.info/ISA#Pinout)
It was about this board:
597.1 KiB
In the mean time I have
- cleaned with a toothbrush
- (temporaly) replaced the crystal and the 8284. Now my Mutlimeter shows 4.77 MHz on the ISA bus
- added missing CAP on C7
- replaced the CPU
665.92 KiB
609.76 KiB
682.21 KiB
But still: Nothing 🙁
Therefore I assumed a bad BIOS. I build this adapter
https://www.elektronik-technik.biz/liste/%234 … rs/READ2364.gif
And read the ROM in my TL866 and the image its exactly the same as the one found in the net. Therefore the BIOS is OK.
For further diagnostic I build the opposite adapter to use the Supersoft ROM:
http://minuszerodegrees.net/5150/motherboard/5150_u33.htm
This is the construction you see on the photo 😎 I verified this with the other Adapter and it works.
But also with the Supersoft-ROM: Nothing. No Beep, nothing on the CGA.
Somebody has an idea where to continue? I suspect some of the logic ICs as some seem to be rusty (as U62 / U79)...but I cannot desolder one after one and check them?
Reply 4 of 20, by stamasd
Good job so far. Since you have a TL866, it has a logic IC test function. If you can find/build an adapter that fits _over_ the ICs you may be able to test them without desoldering. A sort of inverted socket. I have a similar adapter that I can place over eeproms so I can read/reprogram them without desoldering. Looks similar to this (not my picture):
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 5 of 20, by Predator99
stamasd wrote:
Good job so far. Since you have a TL866, it has a logic IC test function. If you can find/build an adapter that fits _over_ the […]
Indeed, thats a very good idea! I think I can build such adaptor with 2 empty IC sockets.
I already ordered some 74LS158, maybe I will test them with the piggyback-method first...
Reply 6 of 20, by Predator99
derSammler wrote:
What are the two non-lit LEDs on the POST card for?
They are from l to r:
Reset
Frame
Irdy
CLK
When the PC is running they should blink. The current behavior is i.e. caused by a missing/damaged CPU or BIOS.
Reply 7 of 20, by stamasd
Another candidate for checking is the 8288 chip, the bus controller. Unfortunately you won't be able to check that one with the TL866 AFAIK.
I/O, I/O,
I/O, I/O
Reply 8 of 20, by derSammler
Be careful here. A normal POST card does not work on a 5150 mainboard since the BIOS simply does not send the POST code to port 80h. So all the card tells you is that the voltages are apparently present and ok.
If you don't know this site already, start here:
http://www.minuszerodegrees.net/5150_5160/MDC … diag_config.htm
If CPU, lower 64 kb of RAM and BIOS are ok, the system should do something at least. If not, you need to check all traces for continuity.
Reply 9 of 20, by stamasd
derSammler wrote:
Be careful here. A normal POST card does not work on a 5150 mainboard since the BIOS simply does not send the POST code to port […]
That's a 5160, but essentially correct. The POST codes go to port 60h, not 80h. POST cards don't monitor port 60.
If you have a logic analyzer you could monitor port A of the 8255 http://www.minuszerodegrees.net/5160/post/516 … point_codes.htm
I/O, I/O,
I/O, I/O
Reply 12 of 20, by Predator99
Short update: I built such "over-IC" adapter but unfortunately it doesnt work while the ICs are in circuit.
I also "piggybacked" the rusty 74LS158s but no change.
I am aware that I dont have to expect any numbers on the post card, but some lights should flash on it while Post-sequence is running and there should also be some noise from the speaker when Supersoft-ROM is installed.
Reply 13 of 20, by douglar
I recently was given a 5150 with a 16K-64K motherboard labeled "1840401 456 XM "
Seems dead. I know that a regular diagnostic card isn't fully useful, but when I put it in, I see the LED lights flash for a fraction of second and then go black.
Looking over the board, there was a rusty lump sitting on the side of the P8259a chip.
Could the repair be just as simple as replacing this chip with a generic replacement ?
Here's a picture of the chip after giving it a brushing--
383.61 KiB
665.62 KiB
Reply 14 of 20, by douglar
I'm going to try the repair.
If it isn't successful, did any vendors make 3rd party boards that fit a 5150 case?
Looks like this one might have the right slot spacing: https://www.ultimateretro.net/en/motherboards/10191
Reply 15 of 20, by douglar
Looks like the rheostat looking thing is by the power is broken, since 1the top /2 of it fell off.
71.34 KiB
A 5-30 pF clock chip trimmer ?
http://www.minuszerodegrees.net/5150/misc/515 … ch_settings.htm
Looks like I only need it if I am doing CGA, yes?
Reply 16 of 20, by snufkin
Looks like it acts as a calibration for all the clocks:
http://www.minuszerodegrees.net/5150_5160/mis … _generation.jpg
From the schematic you can see it's in series with the main 14.318 crystal:
53.73 KiB
So if it's failed open then the clock won't run.
Reply 18 of 20, by snufkin
I don't know much about the analogue side of clocks, but my guess is that the capacitor isn't going to move the frequency very far from the crystal 14.318. I think it's more for making small adjustments. I'd guess that small values will slightly increase the frequency, but go too small and it'll stop oscillating. If you can't find a variable capacitor of the right value then -0° suggests using a 20pF fixed capacitor instead, which might be worth trying just to see if you can get any life at all from the board.
