First post, by anetanel
I got an S3 Trio64+ with 2Mb VRAM on my 486DX4-100, and I'm trying to get the game "Michael Jordan in Flight" work at SVGA resolution.
The game has a config tool with a limited number of display cards to choose from. Most of them use the same driver (a Tseng compatible driver), but none of them is working with my card, except the basic VGA "no driver" option. Here's the list from the VIDEO.TXT file:
Boca Super X SVGAX1 1 Meg|ts1meg.drvBoca Super X SVGAX1 512K|ts512k.drvCardinal VGA 700 1 Meg|ts1meg.drvCardinal VGA 700 512K|ts512k.drvDiamond SpeedStar 1 Meg|ts1meg.drvDiamond SpeedStar 512K|ts512k.drvDiamond SpeedStar 24X|wdi1meg.drvGenoa 7900 VGA 1 Meg|ts1meg.drvGenoa 7900 VGA 512K|ts512k.drvOrchid Pro Design II 1 Meg|ts1meg.drvOrchid Pro Design II 512K|ts512k.drvSTB PowerGraph VGA 1 Meg|stb1meg.drvSTB PowerGraph VGA 512K|stb512k.drvToshiba T4400C|wd512K.drvVideo 7 VRAMII Ergo 1 Meg|v71meg.drvVideo 7 VRAMII Ergo 512K|v7512k.drv
Searching around I found 2 threads here in the forums that mention univbe 5.3, and supposedly a SVGA patch.
I tried using univbe, but as far as I can tell, it did nothing to this game. Maybe I'm not using it right?
And as for the SVGA patch, I was not able to find it.
Any help would be appreciated 😀
BTW, on DOSBox 7.4, when using "machine=svga_et4000" I'm able to run at SVGA when choosing one of the cards that uses the Tseng drivers.
