First post, by feipoa
Do the heat pipes in heatsink/fan units go bad after some years? My loyal Opteron 185 system has started to get flakey, sometimes hang, Chrome crash, etc. If I open Advanced Chrome and play some youtube video and browse eBay, I notice Everest reporting the CPU temperature getting to nearly 80 C. At high load the CPU is at 2600 MHz. If I am just looking at vogons, the CPU goes down to 1000 MHz and the temperature is at 40 C. Advanced Chrome seems to push the CPU harder than other browsers.
I think it is a fair assumption to say that the CPU is over heating. This particular CPU has 110 W of TDP. Does anyone have a cooler recommendation for this kind of space heater? Perhaps something that lasts longer than 2 years. I don't mind replacing a fan every 2 years, but not the whole heatsink.
I'm really just shooting in the dark here,
This thing has no heat pipe and looks like a giant block of finned copper. Cheap too.
https://www.ebay.com/itm/3-Pin-12V-PC-Intel-7 … 98AAOSw~OdVWtZc
This thing has what looks like 4 heat pipes,
https://www.ebay.com/itm/DC-4Pin-CPU-Cooler-H … =item33c0ff9638
Then there is something like this, which is original AMD for Athlon X2. Specifies it is for up to 125 W TDP.
https://www.ebay.com/itm/AMD-Heatsink-CPU-Coo … joAAMXQlgtS1PEN
etc etc...
Do modern CPUs get anywhere near 110 W though? Do I need water cooling? Or just get some 4-piper and replace it every few years? Thanks!
Reply 1 of 156, by stamasd
The first one isn't copper, it's colored aluminum. Look at the picture of the base, the contact surface is aluminum and towards the edges it blends into copper-colored material. They're probably doing that for aesthetic reasons, or to pass it for "real" copper.
I used something similar to the second one in my s939 build several years ago, it performed well while I had it in use. That was IIRC with a Athlon 64 X2 Toledo-core, 4400+ so not 110W but 89W. Also IIRC my temperatures under load with that setup were on the order of 58-60deg C. YMMV.
I/O, I/O,
It's off to disk I go,
With a bit and a byte
And a read and a write,
I/O, I/O
Reply 2 of 156, by wiretap
I would just pick up a Zalman CNPS9500 and call it a day. It can handle a huge heat load. Techpowerup did a test with it using an overclocked Pentium 4 561 (115w TDP oc'd to 4.3GHz @ ~180w TDP) and it ran around 65C at max load. Other options would be Thermalright or Scythe, as they designed quite a few high TDP load coolers that performed extremely well.
Edit, another one I use is the Zalman CNPS10X Extreme. (still readily available on Amazon and Newegg) It is compatible with everything from socket 754 up to socket 2011. I run them with dual Xeon 135w TDP processors and it keeps them nice and cool at load.
My Github
Circuit Board Repair Manuals
Reply 3 of 156, by stamasd
One quick thing you could try before looking for a different cooler would be to reapply thermal paste. I don't know if the heat pipes go bad, but I know thermal paste does and I regularly re-paste my machines every 2-3 years.
I/O, I/O,
I/O, I/O
Reply 4 of 156, by RetroBoogie
So, I had an X2 4200+ running at 2.6 GHz on this cooler: https://www.amazon.com/gp/product/B007BVCBOE/ … e?ie=UTF8&psc=1. While it worked fine in a case with adequate airflow (3 big fans), it was on the edge of what I would consider comfortable. In the end I just went with an old Hyper 212 EVO that I had lying around from a 2500k build and of course the increase in fin area worked much better.
Reply 5 of 156, by gex85
I have never heard a single story of a heat pipe going bad. Which of course doesn't mean that it can't happen, but I'd be very surprised if it did. If your heatsink/fan assembly doesn't perform like it used to, you should first disassemble everything, clean it thoroughly, and re-install it with proper thermal paste like Arctic MX-4. And maybe add some proper case fans to ensure a good airflow through the case.
If you still wish to replace the cooler assembly, you should stay away from this no-name china stuff and instead go for a tried and tested model from a brand manufacturer. There are plenty of models out there with S939 compatibility that are still available new or NOS from eBay.
My retro computers
Reply 6 of 156, by Koltoroc
Avoid the AMD cooler you linked. It is incredibly loud. The newer "wraith" ones would be okay but those old boxed coolers are way too loud to be tolerable.
Cooler compatibility should be not that much of a problem. IIRC (I might be wrong) mounting holes have been the same for most boards since socket 939 only majorly changing with AM4 and the retention modules should support the same coolers for all sockets.
Reply 7 of 156, by The Serpent Rider
Step 1:
Remove CPU IHS with a thin blade/razor. Be careful not to damage small elements near the edges. Patience is the key.
Step 2:
Remove 10+ years old thermal paste from the core.
Step 3:
Apply some fresh and good thermal paste. I recommend good ol' Arctic Cooling MX2/MX4, but there are also better options.
Step 4a:
Put IHS back with adhesive.
Step 4b:
Modify your cooler for direct contact with the crystal. Some may fit even without any modifications.
Reply 8 of 156, by PC Hoarder Patrol
What's your case and airflow like? - probably best with a tower cooler like the CM Hyper 212 Evo / 212X then you can double up to push-pull airflow with a 2nd fan if needed.
Reply 9 of 156, by Bellator
My main system is 939 still (DFI Lanparty nF4 Ultra D), with an Athlon 64 X2 4600+ and an everyday configuration (very relaxed) of 220x12=2640 MHz (1,264 V) with Cool'n Quiet ON (220x5=1100 MHz @ 1,056 V), and 4x1GB RAM. My heatsink is an Arctic Cooling Freezer 64 (not the Pro version, only 2 heatpipes), but with a very well ventilated case:
http://www.cdrinfo.com/Sections/Reviews/Speci … ArticleId=14140
Today's temperatures:
- Room: 26 ºC
- Idle: 36/36 ºC (core 1/2)
- Full load: 51/56 ºC (core 1/2)
Reply 10 of 156, by agent_x007
Thermalright Ultra 120 extreme + this : LINK + Delta Fan = 3,05GHz and 50C at load.
Proof : LINK
Reply 11 of 156, by SW-SSG
feipoa wrote:
This thing has no heat pipe and looks like a giant block of finned copper. Cheap too. https://www.ebay.com/itm/3-Pin-12V-PC-Int […]
Dodgy no-name coolers like these, shipped from overseas on Ebay, are always a poor choice. The AMD stock cooler that you linked would likely work fine, but it won't be quiet. The best option is to look for coolers made by the name-brands, such as the Cooler Master Hyper 212+, Thermalright Ultra-120, and Arctic Cooling Freezer 64 Pro, that use large 92-120mm fans. It may be possible to get used ones for relatively inexpensive.
Reply 12 of 156, by The Serpent Rider
Replacing cooler won't help.
Reply 13 of 156, by shiva2004
I had this cooler with an Athlon X2 6400 rated at 130W and it wasn't up to the task, when I taxed the computer for extended periods of time it overheats and even shuts down, and it also makes a lot of noise; perhaps it can cope with 110W loads, but I wouldn't use it in anything rated above 95W. Also, it isn't worth 47$, not even half of that.
Right now I use an Opteron 180, also rated at 110w, with an Arctic Cooling Freezer 64 Pro and it cools the processor well enough, in a cheap case with moderate airflow I've never seen it to go above 56-57° celsius and most of the time it' s barely audible.
Reply 14 of 156, by Unknown_K
The heatsinks with copper base that were shipped with Phenom II and FX 83x0 chips work fine, just make sure the BIOS controls fan speed (they are 4 wire fans) otherwise they are loud as hell full on.
Reply 15 of 156, by feipoa
Thanks for all the suggestions.
I don't mean to sound like a novice, but I'm looking at photos of what you recommended and I do not see a clip to attach to socket 939. Am I missing something basic here?
https://www.ebay.com/itm/Zalman-CNPS9500-AT-C … EAAAOSwubRXEE0y
Replacing the paste helped some, but the issue is that under max load, this CPU is overheating. My current cooler has two copper heat pipes which attach to some aluminum fins, and a fan.
I'm looking at this photo and wondering where the S939 clip is, https://www.ebay.com/itm/Cooler-Master-Hyper- … 6kAAOSw~YRaiJyN
Well, I am using a no-name from China. To be honest, I had never run Advanced Chrome on this machine before and after using Advanced Chrome, I couldn't believe how much more CPU draw it has than, say, Firefox.
Thanks for letting me know. I almost bought the old AMD cooler. I don't believe my motherboard has any 4 pin fan plugs, so no speed control. OK, so I can use any heatsink I want that is for AM3?
I have some low noise fans in the input to the case, and one on the exit. The PSU also has an input and output fan. We have had a really hot summer.
Bellator wrote:
My main system is 939 still (DFI Lanparty nF4 Ultra D), with an Athlon 64 X2 4600+ and an everyday configuration (very relaxed) […]
- Room: 26 ºC
Hmm, maybe the new models have more heat pipes. I think the Opty 185 gets quite a bit hotter than the X2 4600.
Proof : LINK
That's a beast. Where's the 939 clip?
https://www.ebay.com/itm/Thermalright-Ultra-1 … 0QAAOSw555a2GX5
Well, that's two points for the Freezer 64 Pro. I guess I'll look into this one.
Reply 16 of 156, by feipoa
Wait... It seems like the newer Freezer 64 Pro's have 4-pin connectors. So this thing is going to run full speed at 20K RPM? Won't that be loud? Anything with 3-pins?
Reply 17 of 156, by wiretap
You're linking Ebay (and the Intel version at that), which doesn't show any accessories, so it may or may not come with the right mount. Always check the manual to see what it supports and what mounts it is supposed to come with. Here's a snippet from the user manual..
Detailed in #6 & #7 is the mounting bracket.
My Github
Reply 18 of 156, by feipoa
What about this monster? Claims it can do 160 W.
https://www.ebay.com/itm/ARCTIC-Freezer-Xtrem … IEAAOSwL4lbK0li
EDIT: I keep running into the 4-pin PWM fans. Seems like I need one which is quiet on its max RPM. Seems unlikely.
Reply 19 of 156, by feipoa
I ended up getting the Zalman CNPS9500A because of the 3-pin fan connector. I've been using ceramique 2. Is there something significantly better I should be using?
I'll just not tax my Opty 185 too hard until the new cooler arrives. I suspect a lot of heat problems come from the heatsink not grasping with enough force to smash the compound down flat enough.
EDIT: I remember some time ago, I bought this fancy thermal paste which was silver and claimed to be the best. The stuff was too viscous to smash down sufficiently.
