First post, by jaw1989
jaw1989
Offline
I am using an HP pavilion G Series running linux mint. The first time I use the "L" key in Dosbox it works, then it acts as if I am holding it down. I press another key and backspace to stop. After that "L" Key gives no response what so ever. Tried un-installing and re-installing. Still not working. Tried using key mapper to use alternate key or re bind it. Did not help.
