First post, by readyready15728
I have a working image of MS-DOS 6.22 that I built using the steps here:
https://github.com/readyready15728/misc/blob/ … os-on-dosbox.md
I wanted to get Borland Turbo C 1.5 up and running for old time's sake and took the disk images from REMOVED hen supplied them after "boot" in the config file. I was able to start the installation but not finish it. It asked me for the next disk and used Ctrl-F4 to cycle through all the images, confirming that they were being swapped out through the console messages but none of the images were accepted. Cycled through like three times and no dice. Is there a way out of this?
