First post, by j^aws
I'm looking at a DAW build with either an AMD 890FX or Intel X58 chipset. I'm trying to minimise testing time to get the best latency using a PCI-Express sound card. This card will be the host for digital mixing with live monitoring, so I'm looking for minimal lag.
I understand that there are various factors involved that affect latency, especially Round Trip Latency (RTL). But which aforementioned chipset and OS combination would be the best? It probably depends on chipset/ OS/ ASIO driver combination for a specific sound card?
Possible OS choices are: Win2000, WinXP, Win7, Win8. The digital source will be coming from multiple MIDI modules, and I already have an RME sound card.
Reply 1 of 2, by agent_x007
I say this thing is MB specific, not platform in general.
If you have a crappy board (or one with lots of I/O stuff on PCI-e), latency will be higher.
Same applies to not optimised BIOS and/or OC'ing on top.
Reply 2 of 2, by j^aws
Those make sense. I won't be OC'ing and definitely will check BIOS settings for optimisation.
Regarding boards with lots of I/O stuff on PCI-e, like SATA, USB etc., are you saying keep everything off PCI-e except the sound catd? What about small motherboards like mITX and mATX - would their size affect latency?
My current boards are full size ATX boards - an Asrock for the 890FX with AM3 Socket, and an MSI for the X58 with LGA1333 Socket.
