First post, by Intel486dx33
Here is my refurbished HP Vectra VL/5 200
This computer was a wreck when I received it.
It's a relic of a time when HP dominated Silicon Valley.
If ever there was a game player these HP Vectra's where one.
I cleaned it up and rebuilt it with max ram, dual graphics and added a Fast SCSI, DVD drive.
The HP Vectra was a line of business-oriented personal computers manufactured by Hewlett-Packard.
It was introduced in October 1985 as HP's first IBM compatible PC.
This was HP's flagship corporate class workstation computer in the 1990's
HP's IBM standard PC.
With the Intel 486 CPU based HP Vectra computers and HP Netservers, HP was able to setup a World wide MS-Windows Network using Windows NT 351. This is a time when the internet was just getting started and they where still laying the data cables across the continents and oceans.
In the 1990's HP had campuses all across Silicon Valley and was a major player in the computer industry.
With it’s workstations, Servers, and Network devices. HP was a one stop Enterprise ready solution.
With the HP Vectra, HP 9000, servers, switches and network printers. Instruments and medical equipment. HP was to BIG for it’s own bridges.
HP purchased many companies including Digital and Compaq computers.
HP ended up splitting the company into several divisions.
Eventually closing most of it’s campuses in Silcon Valley.
Today, Apple has built it’s NEW space ship campus on top of the old HP campus in Cupertino. Apple appears to be taking over where HP left off as Silicon Valley's major computer company.
Can the HP Vectra play games?
This guy says it can.
Youtube Video
https://www.youtube.com/watch?v=qs7NTxOI5v4
Manual:
https://www.manualslib.com/manual/276821/Hp-V … ?page=34#manual
Specs.
Assembled in: USA
Manufacture date - 1997
Motherboard - HP, Intel Socket 7
Chipset - TXC chip (82439HX) , PIIX3 chip (82371SB) , Super I/O chip (37C932) .
CPU - Pentium MMX 200mhz.
RAM - max ram 64mb. ( EDO )
Hard-drive - IDE 3.2GB Quantum Fireball ST.
CDROM - IDE DVD ( I will replace with original CDROM later ).
Network - HP Ethernet 10/100 BaseT Network Board It is based on the AMD PCnet-PCI-II 79C971 network processor chip.
SCSI - Fast SCSI 10mbs. ( PCI )
Modem - Intel 56k ( PCI )
Expansion slots - 2-ISA , 3-PCI
PSU - SFF , Wattage 100
Floppy drive - 1.44
Audio
Sound Blaster 16 ( ISA )
Audio Controller
The Creative Labs CT2970 SoundBlaster 16 audio interface, supplied on
some models in an ISA slot, can be summarized as follows:
• line-out (stereo) jack: 20 Hz to 20 kHz frequency response, 83 dB signal
to noise ratio, 0.2% total harmonic distortion
• headphones jack: 2 W PMPO per channel, 32 Ω load
• speaker connector: 0.2% total harmonic distortion
• line-in (stereo) jack: 15 kΩ, 0 V to 2 V peak-to-peak
• CD audio-in connector: 15 kΩ, 0 V to 2 V peak-to-peak
• microphone input: 600 Ω, dynamic, 30 mV to 200 mV peak-to-peak
• MIDI /joystick interface connector: MPU-401 UART compatible
• 8-bit and 16-bit stereo sampling: 5 kHz to 44.1 kHz
• Creative OPL3 synthesizer: 20 polyphonic voices
• typical electrical current: +5 V (250 mA), +12 V (250 mA), -12 V (50 mA)
Graphics ( Onboard ).
S3 Trio64V2/DX
Make: S3
Codename:86C775
Bus:PCI
Memory Size:1MB, 2MB
Max Memory Size:4MB
Memory Type:EDO
Year:1996
Announce Date:Monday, 03 June 1996
Card Type:VGA
Family:Trio
Outputs:15 pin D‐sub
Video Acceleration:MPEG-1 (VCD)
Core:64bit
Memory Clock (MHz):60
Memory Bus Width:64bit
Memory Bandwidth (MB/s):480
Max Memory Clock (MHz):65
Min Memory Clock (MHz):50
Ramdac (MHz):170
Graphics ( PCI )
Matrox MGA Millenium-2 PCI
Matrox MGA Millennium Graphics Controller Board
All models of the HP Vectra XA 5/xxx PC and a few models of the
HP Vectra VL 5/xxx Series 5 PC are supplied with a Matrox MGA
Millennium PCI graphics controller on a board fitted in a PCI accessory slot.
The on-board MGA-2064W processor communicates with the Pentium
processor along the PCI bus. The controller can be characterized as follows:
• 100% hardware- and BIOS-compatible with IBM® VGA display standard
• 64-bit video memory access
• Hardware acceleration of graphical user interface (GUI) operations
• Support for up to 8 MB Window RAM (WRAM) at 50 ns
• Integrated 24-bit, 220 MHz RAMDAC
• Pixel clock maximum frequency of 135 MHz
• Green power saving features
• Standard and Enhanced Video Graphics Array (VGA) modes
• Acceleration for 3D, playback, MPEG (when an optional upgrade module
from Matrox is fitted), continuous interpolation on X, replication on Y
• DDC 2B compliant.
Supported Operating Systems:
Windows-311
Windows-95
Windows-98se
Windows-NT
Windows-2000
IBM-OS2
Photos taken with my 2017 iPad.
    1.45 MiB
    1.73 MiB
    926.55 KiB
    1.48 MiB
Reply 1 of 11, by Intel486dx33
More photos:
    1.48 MiB
    351.06 KiB
    1.9 MiB
    1.66 MiB
Reply 2 of 11, by Intel486dx33
Wallpaper
    744.37 KiB
    640.91 KiB
    175.62 KiB
Reply 3 of 11, by oeuvre
I think I had the same Vectra a while back. They are really nice retro boxes and quite roomy inside for their size. Expandable and well built.
Reply 4 of 11, by Intel486dx33
Restored this HP Vectra with a period correct CDROM drive.
    1.23 MiB
Reply 5 of 11, by SW-SSG
I had a similar Vectra a while back with 486DX2/50 inside. Looked exactly the same; same proprietary PSU and front panel and everything. Hmmm.
Btw, your spec sheet has an error... that "EIDE Seagate 1gb" is actually a 3.2GB Quantum Fireball ST.
Reply 6 of 11, by SpectriaForce
That's a nice looking system.
That must be one of the first pc's with USB 1.0 ports (I see it's from ca. week 36 1997).
From Wikipedia:
USB 1.x
Released in January 1996, USB 1.0 specified data rates of 1.5 Mbit/s (Low Bandwidth or Low Speed) and 12 Mbit/s (Full Speed).[21] It did not allow for extension cables or pass-through monitors, due to timing and power limitations. Few USB devices made it to the market until USB 1.1 was released in August 1998. USB 1.1 was the earliest revision that was widely adopted and led to what Microsoft designated the "Legacy-free PC".[12][13][14][15]
Neither USB 1.0 nor 1.1 specified a design for any connector smaller than the standard type A or type B. Though many designs for a miniaturised type B connector appeared on many peripherals, conformity to the USB 1.x standard was hampered by treating peripherals that had miniature connectors as though they had a tethered connection (that is: no plug or receptacle at the peripheral end). There was no known miniature type A connector until USB 2.0 (revision 1.01) introduced one.
I've had an IBM Aptiva from January 1997 without USB ports and recently found out that USB ports became standard equipment just a couple months later.
Thanks for sharing wallpapers 😊
Reply 7 of 11, by flecom
nice wallpapers! I have been playing with a Vectra VL/6 200 recently (similar specs just pentium pro)... my favorite part is the 10/100 nic that was included with the machine... it's not auto-sensing... literally has one port for 10 only, one port for 100 only, wild!
Reply 8 of 11, by Intel486dx33
Yeah, I remember working with rooms full of these HP Vectra's. They were real work horses.
In the older 486 models they had Seagate hard-drives and when they got old they made a terrible whining noise.
it was very irritating. But these Vectra's ran allot of government and corporate America back in the 1990's
Reply 9 of 11, by justajeffy
I recently got a Vectra VL/5 200 and I'm having trouble getting into the case. If other Vectra VL/5 owners haven't seen my other thread, I'd really appreciate if you'd have a quick read: Opening HP Vectra VL Case
Thanks!
Reply 10 of 11, by kainiakaria
I am in the process of upgrading my HP Pavilion 7410P. I just need to get an ISA NIC Ethernet card.
August 24 of this year, I went to the thrift store and just bought for 10 us dollars an HP Pavilion 7410P. I am planing to throw a a 3Dfx Voodoo 1 in it. I currently have a ATI 3D Rage Pro coming in the mail.
Estimated Price Range: $899 to $3,550 US Dollars
Basic Specs
_____________________________
Chipset: Intel i430FX Chipset or Intel i430HX Chipset
Motherboard: Intel Ruby RU430HX [Proprietary Computer Case Specific Socket 7 Motherboard]
CPU Type: Has either Intel Pentium Classic [The A80502120, A80502133, A80502150, A80502166 and A80502200 were used on this series of PC. These systems seem to have mostly come originally with Pentium Classic and later offered with Pentium MMX versions.] or Intel Pentium with MMX Technology
Max Memory (Able to Take): 128 MB (4 sticks of 32 MB) EDO SIMM NON Parity but I think that they might be able to pull off 512 MB
Max Hard Disk Drive Capacity Support: 8 GB
USB Version: USB 1.0 [Only on the models that came with Windows 95 OSR2.1]
AGP Slot: None
Max Amount of PCI Slots: 2
Max Amount of ISA Slots: 5
Max Amount of Serial Ports: 1 to 2 COM Ports & 1 Parallel Port
PS/2 Port Implementation: 1 Keyboard & 1 Mouse
Max Amount of USB Ports: 2
Max Amount of Hard Disk Drives That It Can Take (3.5 Inch Bays That Are Above the Power Supply): 2
Max 5.25 Inch Drive Bays (Front): 2
Max 3.5 Inch Drive Bays (Front): 2
Stock Hard Disk Drive: Quantum Bigfoot (5.25 Inch) Hard Drive In Removable Tray
Onboard Graphics: S3 Trio 64/­32 Chipset or S3 ViRGE Chipset with 2 MB of VRAM [In terms of higher end models I would recommend either the NVIDIA RIVA 128 PCI or the ATI 3D Rage Pro PCI if the 3Dfx Voodoo 1 cannot be obtained and even if you do get a 3Dfx Voodoo 1 then I still recommend either of these]
Onboard Sound: Crystal CS4232 or Yamaha OPL3-SA [These support Sound Blaster Pro 2.0]
Modem Card: Pavilion PC Lucent Modem
Ethernet LAN Card: None [You will have to add one in. I recommend an LAN card that uses the ISA Bus]
Operating Systems: Windows 3.1, Windows for Workgroups 3.11, Windows 95 OSR1 or Windows 95 OSR2.1
Reply 11 of 11, by Intel486dx33
Nice clean case.
You probably want and ISA NIC like the “3com 3c509b etherlink-3”
Or
An “Intel Pro 10 ISA”
These provide good support for DOS, Win3x and Win95/98
WInNT3x and WinNT4x and Win2000
Etc....
