Hi, ok here are some points of interest (or not 😊)
- Tried Carmageddon 2 with dgVoodoo and it works without crashing.
- I run dgVoodoo by putting it in the game folder.
As for the settings, these are the default settings, adjusted to 32bit Hardware T&L with forced bilinear filtering.
This might be a Carmageddon 1-only error. Perhaps you could download (or whatever) the game with the 3dfx patch and see if you get the same problem.
Small question, are you referring to Test Drive Offroad 1? Because I didn't know that game can run on 3dfx 😮
One more thing, there seems to be a universal problem with glide wrappers that hits the game Carmageddon. In a couple of races, the game craches back to desktop on random events. This problem has already been confirmed at the Glidos webpage. The first level I'm having the problem with is 'Fridge Racer'.
I still have an old Voodoo 2 card laying here somewhere, so I might try running Carmageddon on that one and see if it's in fact a bug in the 3dfx version instead of some glide wrapper issue that triggers the crashes.
