First post, by Intel486dx33
Here is my restored IBM 350 Personal Computer ( desktop PC ).
It was a wreck from Michigan Great lakes area with some moisture corrosion damage on the case frame
but the electronics are good.
I have a couple of these. They are great for DOS/Windows-3x/WinNT351/WinNT-4.0/Win95.
Really easy to setup and reliable. Easy to fix too. No IBM proprietary parts. PC standard.
IBM Desktop PC 350 The PC 350, introduced over 1994 to 1995,[1] was a middle-class model, having the same motherboard as the PC […]
IBM Desktop PC 350
The PC 350, introduced over 1994 to 1995,[1] was a middle-class model, having the same motherboard as the PC 330 in a much roomier case with additional drive bays. Processors ranged from the 486DX2-50, 486SX-20, 486DX4-100 to the Pentium 200. It had, depending on the sub-model up to 5 ISA and/or 3 PCI expansion slots and five (2 external 5.25 inch, 1 external and 1 internal 3.5 inch) drive bays. It had in its last version, just like the 330, 1 DIMM-168 and 4 SIMM-72 RAM slots, and featured an IBM SurePath BIOS.Submodels were:
Name Model CPU MHz Remarks
IBM Personal Computer 350 Model 6578-5xx, 7xx
IBM Personal Computer 350 Model 6581-Kxx, Lxx, Wxx Intel 486 20-100 up to 128Mb RAM in four SIMM-72 slots
IBM Personal Computer 350 Model 6583-Kxx, Lxx, Wxx
IBM Personal Computer 350 Model 6585-1xx Intel Pentium P5 60-66 up to 133MHz using the Pentium overdrive
IBM Personal Computer 350 Model 6586-3xx, 4xx, 5xx, 7xx, 9xx Intel Pentium P54C 75-100mhz
IBM Personal Computer 350 Model 6587-5xx, 7xx, 9xx, Gxx, Kxx, Lxx Intel Pentium P54C 75-200mhz up to 192Mb RAM, CPU up to 233MHz using a Pentium 233MMX with 75 MHz settings.
Specs […]
Specs
GENERAL
Type - Personal computer
Recommended Use - corporate business, small business
Product Form Factor - Desktop
Manufacturer - IBM
PROCESSOR / CHIPSET - CPU Intel Pentium MMX 200 MHz
Data Bus Speed - 66 MHz
Processor Socket - Socket 7
CACHE MEMORY:
Installed Size L2 cache - 256 KB Write-Back
Type L2 cache - Installed Size 256 KB
STORAGE:
Interface Type EIDE
RAM - Installed Size 16 MB / 128 MB (max)
Technology EDO RAM - non-ECC
Memory Speed 66 MHz
Access Time 70 ns
Upgrade Rule 2 modules at a time
Technology EDO RAM
Data Integrity Check non-ECC
MEMORY
Max Supported Size - 128 MB
Form Factor - SIMM 72-pin
DISPLAY
AUDIO & VIDEO
Supported Display Graphics SVGA (800x600), SXGA (1280x1024), VGA (640x480), XGA (1024x768)
Analog Video Format none
HARD DRIVE
Interface Type EIDE
Type HDD
Interface Class Parallel ATA
Installed Qty 1
Capacity 1.2 GB
STORAGE CONTROLLER
Interface Type EIDE - Type IDE
Bus Type PCI - Installed Qty 1
INPUT - Type keyboard, mouse
OPTICAL STORAGE
Drive Type - optical drive
PROCESSOR
Installed Qty 1
Max Supported Qty 1
Upgradability upgradable
Type Pentium
Manufacturer Intel
Clock Speed 133 thru 200MHz
FLOPPY DRIVE
Type 3.5" 1.44 MB floppy
STORAGE REMOVABLE
Type none
HEADER
Brand IBM
Product Line IBM PC 350
Model 6586
Packaged Quantity 1
Compatibility PC
MISCELLANEOUS
Color white
Features boot without keyboard or mouse, diskette I/O control, hard drive I/O control, parallel port I/O control
Compliant Standards Plug and Play
SYSTEM
Type personal computer
Hard Drive Capacity 1.2 GB
OS Certified IBM OS/2 Warp 3.0, IBM PC DOS 6.3, Microsoft Windows 3.11
MONITOR
Monitor Type None.
GRAPHICS CONTROLLER
Form Factor integrated
Interface Type PCI
Graphics Processor S3 Trio64
Video Memory 1 MB / 2 MB (max)
Video Interfaces VGA
DIMENSIONS & WEIGHT
Width 17.1 in
Depth 18.3 in
Height 6.5 in
CHASSIS
Form Factor desktop
Manufacturer Form Factor desktop
Built-in Devices none
MANUFACTURER WARRANTY
Type 3 years warranty
MAINBOARD
Processor Socket Socket 7
Data Bus Speed 66 MHz
PRINTER
Type none
EXPANSION / CONNECTIVITY
Bays 2 (total) / 2 (free) x external 5.25" x 1/2H
1 (total) / 0 (free) x external 3.5" x 1/3H
1 (total) / 0 (free) x internal 3.5" x 1/3H
1 (total) / 1 (free) x internal 3.5" x 1/2H
Slots 2 (total) / 2 (free) x shared PCI / ISA - full-length
2 (total) / 2 (free) x ISA - full-length
1 (total) / 1 (free) x ISA - half-length
1 (total) / 0 (free) x CPU
4 (total) / 2 (free) x memory - SIMM 72-pin
PHYSICAL CHARACTERISTICS
Form Factor desktop
Weight 28 lbs
POWER
Type power supply
Compliant Standards EPA Energy Star
Nominal Voltage AC 120/230 V (50/60 Hz)
OPERATING SYSTEM / SOFTWARE
OS Provided: Type Microsoft Windows 95
OS Provided Microsoft Windows 95
Type Drivers & Utilities
VIDEO OUTPUT
Interface Type PCI
Graphics Processor Series S3 Trio
VIDEO MEMORY
Installed Size 1 MB
SERVICE & SUPPORT
SERVICE & SUPPORT DETAILS
Type limited warranty
Service Included parts and labor
Location carry-in, on-site
Full Contract Period 1 year, 3 years
GENERAL
ManufacturerIBM
Add-ons:
Sound Blaster 16 Vibra ( ISA )
AMD PCNET Family PCI Ethernet Adapter ( PCI )
Photos taken with my 2017 iPad.
