Attached is an image of what I plan on whitening up. I've shown it next to a non-yellowed drive bezel to offer perspective.
The attachment Yellowed_5.25_inch_drive.jpg is no longer available
EDIT: I have some items which have printing over areas needing retrobrite. Will the printed lettering come off in the process?
The attachment Yellowed_bezels.jpg is no longer available
EDIT: So I've found a few more items for the first test run. The LS-120 drive and the white 5.25" drive are only in the photo for a white balance comparison. The Travan drive bezel, the DVD drive bezel, and two 5.25" bezels will be soaked. The middle 5.25" bezel isn't very yellowed, but you can see it isn't as white as the bottom bezel. It has that black arrow on it though. Will the black fade on this? If so, perhaps I shouldn't soak it.
EDIT2: Apparently, you can pour in hydrogen peroxide to a pot of water and heat it at 150 F, e.g. the warming zone, for 5 hours without needing UV light.
