First post, by MKT_Gundam
I got a a MSI HETIS 865GV-E with celeron D 2.8gHz
https://www.msi.com/Desktop/Hetis_865GV ... e/Overview
This machine has only 1 2 pci slots but 1 slot is broken.
For the video card, installed a Diamond Stealth III S540 32MB.
The board feature intel Extreme Graphics 2. For win98SE games, this IGP will works well?
I have a pci voodoo 2000 and banshee but the machine is hot a lot.
Retro rig 1: Asus CUV4X, VIA c3 800, Voodoo Banshee (Diamond fusion) and SB32 ct3670.
Retro rig 2: Intel DX2 66, SB16 Ct1740 and Cirrus Logic VLB.
Reply 1 of 15, by F2bnp
The IGP might actually be faster than the Savage 4 you installed. In any case, the difference between the two in performance probably won't be great.
Reply 2 of 15, by dr.zeissler
The i865gv-e is a faster i845gv which is a really good retro-igp.
The DOS compatibility is excellent. The features are good (s3tc).
I had an issue with "soldier of fortune", the framerate is shortly extremly low while shoot an enemy and displaying a sort of flashlight. I can't figure out what causes this.
Another thing is that there was no fullscreen in Win2k for Crack-Remakes (remakes.org).
Reply 3 of 15, by MKT_Gundam
I gonna try with v3 2000. I will add some extra cooling in the case.A pci fan blower like this one: https://www.amazon.co.uk/Case-System-Exhaust- … r/dp/B0043QUS7W.
Also, the P4 prescott are unlocked? The bios has option to change fsb/voltage but for celron D is locked. Maybe putting a underclocked p4 will help to lower the heat.
For DOS the on board sound (ac97 crap) features sb digital voices and the MS GM. Teste with warcrfat 1 and 2, DOOM 2 and Dark forces. In dark forces only sfx sound worked. For 3d games with S4, UT and half-life blue shift at 640x 480. Both worked fine.
Reply 4 of 15, by weldum
there are no unlocked p4 processors, all are multiplier locked, in many motherboards you can change fsb and voltage, it has nothing to do with being locked. being a prescott, it may feature speedstep, that way you can lower the multiplier, but still that computer should not be that hot.
DT: R7-5800X3D/R5-3600/R3-1200/P-G5400/FX-6100/i3-3225/P-8400/D-900/K6-2_550
LT: C-N2840/A64-TK57/N2600/N455/N270/C-ULV353/PM-1.7/P4-2.6/P133
TC: Esther-1000/Esther-400/Vortex86-366
Others: Drean C64c/Czerweny Spectrum 48k/Talent MSX DPC200/M512K/MP475
Reply 5 of 15, by MKT_Gundam
The case is very compact just a very small lateral fan. even the ram has heatsink.
Also the IGP from that time are based on Intel old video card?
Reply 6 of 15, by zyga64
Try P4 Nothwood. They are really much cooler without noticeable loss of performance.
8088@8 /640k /TVGA9000C /ALS100+TNDY 3voice
286@20 /4M /CL-GD5422 /CMI8330
486DX33 /16M /TGUI9440 /GUS+ALS100+MT32PI
K6-2@400 /64M /MGA-2064W+3dfx /YMF718
P!!!750 /256M /MX440 /Vibra16s+SBLive!
Reply 7 of 15, by dr.zeissler
I am using a P4 with a C100-Futro. It's a 800Mhz FSB that the machine clocks down to 400Mhz.
So instead of 2,4Ghz I only have 1,2Ghz and therefore much less TDP. (should be half so ca. 30 Watts !
Reply 8 of 15, by MKT_Gundam
Today tested games with daemon tools. The audio streamed from the iso gets some stuter. Also the windows starting music gets stuter. I gonna try with the intel igp and pci sound card.
My options for cards are:
sb live 4670´model with gold plated conector
Ensoniq audio pci
Aureal vortex 1
I found infos about the igp
https://www.tomshardware.com/reviews/integrat … ance,674-4.html
https://techreport.com/review/5158/intel-865p … 865g-chipsets/9
Reply 9 of 15, by dr.zeissler
That stuttering sound within win9x is a problem my solo1 with wdm-drivers has too in that FSC-C100 (i845gv) machine.
Also some strange noises whithin unreal-engine-games are clearly audible. I'll have to do some more testing.
The extreme-gfx is still fine for retro. It can take the advantage of jazz2 640x400@8bit with the stutterung-free scrolling.
Reply 10 of 15, by zyga64
I would check DMA for harddisks first.
Reply 11 of 15, by MKT_Gundam
In the bios just have the option to assign IRQ for PNP or ISA ( the mobo dont have any ISA slots. Already changed and still the issue.
I disabled the serial and Print ports.
The "universal" driver on realtek site ( ver. 4.06) dont work.
Also the extreme graphics is just a powered vrsion of Intel 710?
http://www.vgamuseum.info/index.php/component … m/195-intel-740
Reply 12 of 15, by zyga64
MKT_Gundam wrote:
In the bios just have the option to assign IRQ for PNP or ISA ( the mobo dont have any ISA slots. Already changed and still the […]
Speaking about DMA, I meant checking in Windows "device manager" for hdd/controller. Also make sure that last "Intel Inf" package is installed for this chipset.
Those PNP/ISA options in BIOS (in my opinion) are just for reserving resources not to be automatically assigned to PCI devices. Setting them to 'ISA' prevents assignment.
Extreme Graphics 2 (embeeded in i865G) is next step in their "slow" evolution of graphics chips i740->i815->i845->i865
Reply 13 of 15, by dr.zeissler
inf is installed, dma is activated.
Reply 14 of 15, by MKT_Gundam
Just downloaded On MSI site the inf.
Also for dos gaming via windows i get sfx/voices with theses settings in games setup:
SFX: Sb irq:5 DMA:1
Music: General MIDI: 330
Tested Descent 2. In game music works
Legend of Kyrandia 2: Only MIDI music.
Tyrian 2000: only MIDI music
Reply 15 of 15, by MKT_Gundam
Removed S4 pro and put a Aureal vortex 1. No more stutters even using daemon tools. Starcraft no more stuter and mcuh better than ac97
Now another Problem: No driver for SB emulation I got the Error n. 6
EDIT after updating with intel chipset drivers from Phils and messing around the bios, i got sb emulation.
